AOD question
Old Dec 20, 2002 | 05:27 PM
marragtop's Avatar
marragtop
AOD question
Old Dec 21, 2002 | 10:00 AM
fulldressxlt's Avatar
fulldressxlt
AOD question
just bought a 96 f150xlt. I have seen references to an overdrive light and turning the o/d on and off. Where is this, how do you do it?
Old Dec 21, 2002 | 10:05 AM
steve83's Avatar
steve83
AOD question
That truck probably has an E4OD or a 4R70W. The AOD doesn't have an OD light; it has an OD and a D position in the shift indicator below the speedo. The E4OD & 4R70W have a button on the end of the shift lever and there's a little "O/D OFF" light on the shift **** facing the driver that comes on when it's disabled.
Old Dec 21, 2002 | 10:08 AM
Supercab's Avatar
Supercab
AOD question
On the end of your shift lever you will see the button, if you push it IN your OD light should come on reading OD OFF, this will keep your trans from shifting into OD, or can be selected at any time to slow your truck down.
Old Dec 21, 2002 | 11:54 AM
fulldressxlt
AOD question
kewl thanx guys
