Rear brake issues 2003 E350
Old Apr 17, 2011 | 05:32 PM
pappy1's Avatar
pappy1
I have a problem with the brakes on my 2003 E350. If the van sits overnight the right rear brake locks up when I go to pull out. I have to back up and pull forward a few times to get it to unlock. I pulled the wheel off and every thing is fine (No binding ) The van sat for about a year before I bought it. The only thing I can think of is a piston is hanging up. Any ideas or suggestions ???
Old Apr 17, 2011 | 11:31 PM
65F1005.8's Avatar
65F1005.8
possibly a parking brake cable hanging up in the sleeve. are you setting the parking brake?
Old Apr 18, 2011 | 03:32 AM
pappy1's Avatar
pappy1
No, I'm not using the parking brake. Thanks for the reply
Old Apr 18, 2011 | 04:51 AM
vandemonium's Avatar
vandemonium
Not sure why just one side would do that. I had plenty of trouble with my 2006 E350 during the first 50,000 or so miles on both sides. I had it in to dealer every few months for calipers hanging up over over half a dozen times.
Told them several times to lube the pins and brakes always worked fine for a while upon return. Finally I had had enough (after 3 sets of pads and a new pair of rotors, all ruined by hanging calipers).
So I took them off myself, lubed the pins with a high quality high-temp grease, re-installed, and no trouble since...it's been a year+ now.
I don't know what the dealer did or whether there is a recommended procedure, but my fix worked. I have read that anti-seize is the recommended fix.
It isn't a highly technical procedure and may violate all the "rules", but it worked for me. I would recommend having a heavy hunk of wire available to hang the caliper from while fooling around, so it doesn't have to hang from the hose.
I hope this helps.
Old Apr 18, 2011 | 05:04 AM
pappy1's Avatar
pappy1
Thanks for the reply Van, I did exactly what you did and it didn't help. I had a Chevy Dually that did the same thing but that seemed to do it more when it was damp outside. Glad to hear I'm not alone with this problem.
luv2wire
Jan 20, 2024 09:01 AM
47CP
Oct 29, 2011 05:31 AM
longboardguy
Oct 28, 2008 08:44 AM
phil haffcke
Jan 31, 2006 10:45 AM
Bubtoofat
Mar 2, 2005 06:34 PM
