My 95 f350 will run for a bit, and then starts missing , then dies. I have changed, the lift pump, and lines to lift pump, also the, in tank pumps, and still it does this. any ideas would be helpfull. Im wondering if cam sensor would do this?
If it restarts again when cold , it may be a HP oil issue too
went back through my posts, and I need to quit working on two vehicles at once in my head, im redoing my 85's fuel system and trying to work on this one as well. Just called the tow truck, let ford figure it out, i aint got time cause im 400 miles from home
