Question about swapping Turbo compressor wheel?
Old Apr 16, 2011 | 10:11 AM
plgebbia's Avatar
plgebbia
I would like to swap compressor wheels on my truck, the one on it now is nicked up. I have a perfect used one I can swap, just wondering if it would cause a balance issue?
Thanks,
P.S. For those of you who know about it from my way too long ago previous post, I am finally getting my injectors installed and fixing my plenums.
Old Apr 16, 2011 | 11:52 AM
F350-6's Avatar
F350-6
I've always just swapped the wheel without getting the shaft assembly balanced. I believe most others here do the same. The wheel itself is balanced so I say screw it on there and go.
Old Apr 16, 2011 | 11:55 AM
plgebbia's Avatar
plgebbia
Thanks! That's what I will do then.
Old Apr 16, 2011 | 12:05 PM
Talyn's Avatar
Talyn
Just past hand tight.
Over tighten and you'll strip it out like I did with mine. =*(
I grab it by hand and crank it down, (carefull, its sharp) then snug it just past that with the wrench.
It will tighten itself further on its own if it needs more from air resistance.
Old Apr 16, 2011 | 12:06 PM
Talyn's Avatar
Talyn
Should swap in new bearings and seals since you'll have it apart.
Clay has an OEM replacement kit.
The ones on Ebay are chineese junk.
Old Apr 16, 2011 | 12:15 PM
plgebbia's Avatar
plgebbia
Thanks for the pointers Talyn! I think I'll skip the bearings etc. for now cause they are in good shape, and I have to get it out of my shop ASAP, can't have paying customers waiting If I had the time, I could be doing stuff on my truck for two weeks straight.....
Old Apr 16, 2011 | 01:17 PM
Talyn's Avatar
Talyn
I hear yea there Ian.
You have to take the turbo out to swap it, 4 more bolts and you'd have the assembly apart and swap the bearings and seals quick.
Was just a thought. =)
Seals are what I see going bad before the bearings.
You'll need to put a wrench on the exhaust side also. If you have the EBPV in still, you'll have to take that sleeve off there to get to the bolt. It's easier to hold a wrench on there without a socket on it.
Old Apr 16, 2011 | 02:30 PM
plgebbia's Avatar
plgebbia
Yea, the turbo is on my workbench. Suprisingly, it only took me 45 min. to get it out, and I had never pulled one in a OBS truck before.
Do you know if permatex Ultra Black is fine to reseal the plenums?
Old Apr 16, 2011 | 03:29 PM
rideracelivemx7's Avatar
rideracelivemx7
ive used that stuff and blew it with in a couple hundred miles. ford sells powerstroke silicone at like 15-18$ a tube. trust me, dont skimp on this. i did mine a second time because i thought i would be fine. that ford stuff is no joke!
Old Apr 16, 2011 | 04:23 PM
Talyn's Avatar
Talyn
I hope you bought new o-rings.
NEVER re-use o-rings.
if you didn't pull it from the pedestal, then you'll only need a set. I think I still have 1 extra set, not sure. If you need them that is.
Old Apr 16, 2011 | 04:34 PM
plgebbia's Avatar
plgebbia
Thanks, I did get new O-rings. Thanks again for the offer.
Old Apr 16, 2011 | 04:46 PM
Talyn's Avatar
Talyn
Yeah, they look like flattened doughnuts.
I was quite amused when I pulled my turbo the first time.
Old Apr 17, 2011 | 07:50 PM
redman84's Avatar
redman84
Subscribed. How the hooha did you get it out in 45 mins?
Old Apr 17, 2011 | 09:51 PM
plgebbia's Avatar
plgebbia
I'm just really good at it... jk. No, honestly, I don't know how I got it out so fast.
Old Apr 17, 2011 | 09:56 PM
pjwoolw's Avatar
pjwoolw
Your supposed to reseal the plenums with the Ford/ Motrocraft hard gray stuff. Can't recall the name. I think dieselorings.com carries it.
