390 is smoking
Old Apr 15, 2011 | 12:46 PM
healthful's Avatar
healthful
390 is smoking
Hello to you all.
My 390 is smoking from the passenger side exhaust when at fast idle, when the gas is let off on the road and at no throttle down hills. It is also blowing smoke and hot air through the valve covers on both sides. Recently found the trans modulator was bad and sending trans fluid to the intake, fixed that and hope this hasn't hurt the rings or valve guides and seals.
I thought that because it smokes out of the exhaust only under specific situations that someone here might have words of wisdom for me.
THANKS!
Old Apr 15, 2011 | 01:21 PM
montana_highboy's Avatar
montana_highboy
Worn guide seals usually smoke on start up, idle, and deceleration when manifold vacuum is at its highest and oil gets pulled down the guides.
Old Apr 15, 2011 | 01:37 PM
healthful's Avatar
healthful
Thank you! I am hoping the seals were the culprits. I'll post the outcome of the new seals.
Old Apr 15, 2011 | 01:40 PM
montana_highboy
That's my best guess based on your description.
Old Nov 1, 2011 | 09:58 PM
healthful's Avatar
healthful
I replaced guide seals on one side to no avail. It must be an oil ring .
SCRebel
1997 - 2003 F150
15
Jul 21, 2013 08:28 PM
byro01
Jul 12, 2010 04:51 AM
iontkendall
Dec 4, 2006 09:40 PM
Steve A
Dec 2, 2004 10:31 PM
wckdclwn911
Apr 18, 2004 08:15 AM
