Por-15
Old Mar 19, 2003 | 05:43 PM
Jag Red 54's Avatar
Jag Red 54
Por-15
Has anybody used the Por-15 Metal Ready? I am fixing some spots in my old primer where the rust spots are starting. I sanded the primer off down to nice clean metal. Then I applied the Metal Ready and let it set overnight just like the instructions directed. The next day I washed it off with water. A slight film developed on the various locations I had treated. Some were white, some were golden tan and some were a rainbow of colors. The supplier says this is normal. He claims that it is a coating of zinc phosphate(?) that sometimes appears as diffetrent colors. Has anybody else used this product? It is supposedly a muriatic acid solution with, I believe, a mix of zinc phosphate to create the final coating on the bare metal.
Old Mar 19, 2003 | 05:52 PM
Schoonie48F2's Avatar
Schoonie48F2
Por-15
Hey John, put this post on the bodywork forum, Carlene has lots of info on it, she and alot of other people have used all the POR-15 products. They have convinced me.
Old Mar 19, 2003 | 06:59 PM
286merc's Avatar
286merc
Por-15
Spend some time reading the info on www.zerorust.com Then explore some of the links, especially to www.autobodystore.com forum where lots of pro bodymen hang out.
I sell ZeroRust so Im biased but the only reason I sell it was after several POR problems and horrible customer support. Found ZR by accident.
Old Mar 20, 2003 | 08:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Por-15
286,
Is zero-rust comparable to POR-15? I was thinking about wire brushing my frame and then painting it with something like POR-15. Would zero rust work the same? Can you weld on it or do I need to complete all the welding first?
Old Mar 20, 2003 | 08:17 AM
Carlene's Avatar
Carlene
Admom
Por-15
Hi John - I'd welcome you to the Bodywork forum, but "You Didn't Check With Us There".
I've used Metal Ready quite a bit and what you described is exactly what it does. I haven't had any problems and have no complaints about any of the POR products I've used.
(And no - I don't sell them.)
As 67Pearl mentioned, do a search through the Bodywork forum and you'll find a lot of info on the subject.
Vern, you slipped in on me.
Do the welding first if you can. If you need to throw paint on first, you'll need to wire brush the area you're gonna weld later to get you back to the metal.
Old Mar 20, 2003 | 08:27 AM
Huntsman's Avatar
Huntsman
Por-15
I would do the welding, blast the frame and then apply the POR. Por 15 is not a weld through type paint, more like a epoxy. Also they do not recommend wire brushing a frame to remove the rust. Blasting or grinding is the method of choice since they do not close the pores in the metal like brushing does (Better adhesion).
Old Mar 20, 2003 | 09:16 AM
Jag Red 54's Avatar
Jag Red 54
Por-15
Thanks for the feedback. I feel much more confident now. I will check out the bodywork forum. I am just too focused and stuck in my ways I guess, I just keep coming to the regular old hangouts. I'll see you there Carlene! Thanks again, John
Old Mar 20, 2003 | 05:09 PM
DS02F250's Avatar
DS02F250
Por-15
I used POR-15 on the frame, underside, and cab of my truck. Works pretty good IF you follow all 3 steps. I forgot a step on the roof of the interior of the cab. When I went to put the DynaMat on, it peeled the POR-15 right off. Dowt! My bad....
Another boner from yours truly...
Daryl
Old Mar 20, 2003 | 08:41 PM
286merc's Avatar
286merc
Por-15
Vern, ZR is nothing like POR15.
It forms an impervious chemical bond with rust but yet is applied like a paint because it is. It is not a "converter" nor is it a thick epoxy carpet like POR that doesnt look very good on a frame or other visible metal.
ZR goes on in very thin coats, it doesnt have to suffocate the rust; it can be welded thru, repaired, painted over and anything else you can do with a paint. Use it as a base coat, top coat (comes in 10 colors) or paint over with just about anything.
It is now being used by performance suspension companies as they have found it to be very durable and looks great.
Out our way, Ive been selling to truck, landscape, and snow plow outfits that have been very dissapointed with POR15. Lots of repeat business as new equipment is added.
90+ % of my ZR sales is Industrial. Shade tree mechanics are slow to catch up to technology as POR has done a good job keeping them uneducated. or is it brainwashed?
Old Mar 21, 2003 | 07:07 AM
GreatNorthWoods
Por-15
Carl,
Thanks for the info. I'll get with you on the zero rust.
Old Mar 21, 2003 | 01:30 PM
j gibbs's Avatar
j gibbs
Por-15
Carl,
I don't mean to change the subject from POR-15 to Zero Rust, but I'm going to.
Can ZR be applied over rust?
John
Old Mar 23, 2003 | 07:09 PM
Ken2600's Avatar
Ken2600
Por-15
I'm interested in the differences too since I'm about to coat my frame, springs, and a few other items with something.
I'm particulary interested in whether zero-rust is flexible enough to last after being applied to coil and/or leaf springs and also chip resistant enough to be used on undercarriage stuff that will be exposed to alot of rocks/gravel/etc.
Old Mar 23, 2003 | 09:06 PM
286merc's Avatar
286merc
Por-15
As far as flexible is concerned it is better than regular paint in that respect. It is not brittle.
As far as chip resistant, the suspension companies that are using it believe so. Is it as chip resistant as POR? No, not unless you put it on in as many layers as POR which defeats the the original purpose; killing rust with very thin coats and looking like a real paint job.
POR looks pretty hokey, especially when brushed on and you cant spray it without an air suit.
I did the front suspension, 4 backing plates (both sides), wheel cylinders, hardware and drums on my 68 Impala about 15K miles ago and it still looks fine. I wasnt doing a resto, just wanted to keep it from deterioating until I got around to a frame off which now isnt going to happen, I enjoy driving it too much. ZR, once cured, is not affected by brake fluid, POR is. I dribbled lots of brake fluid trying to get those damn brakes working properly as proof!
Industrial customers include utility companies, trucking outfits and construction equipment. They all seem pretty happy about the durability.
Old Mar 25, 2003 | 02:24 AM
ke6bnl's Avatar
ke6bnl
Por-15
I used zero rust on my frame and I did the leaf springs then used teflon liner between spring. I used it on the brake backing plates. For the back plates and the 9" reare end I just went over it with out any additional prep with a gloss black spray paint can and it came out great, not sure if that is a recomended proceedur but the backing plates have been that way for a year in the weather. Ed ke6bnl.Brake cyl that were not painted are all rusted up, along with some of the parts on the mustang II suspension not painted. Ed ke6bnl So. Calif.
Old Mar 25, 2003 | 11:58 AM
CustomCab4x4's Avatar
CustomCab4x4
Por-15
I certainly can't dispute your comments about Zero-Rust, I have never tried it. I have heard nothing BUT good about it though, and intend to try some soon. I would however say that in the years and years that I have used POR-15, I've never once seen the need to spray it as it leaves such a fine finish and goes on so well by simply brushing it on. (no waste or mess due to overspray either) The only time I've ever seen brush marks is when you go over it again after it has started to take a set. When applied according to directions, Iv'e never seen it look "Hokey".
Your milege may vary. Later, Phil
<"POR looks pretty hokey, especially when brushed on and you cant spray it without an air suit >"
