please help, oil leaking on dr side exhaust
1985 f150 4x4 351w ho oil is leaking out onto the drivers side exhaust manifold cant seem to locate the source, and the oil pressure is extremely high?? i had a valve cover gasket that started leaking and fixed that shortly after that it has started the other leak i cant locate. would it have something to do with too high oil pressure. does anybody know why it might be so high. thanks a bunch
If you are still going by the stock gauge, invest in a mechanical gauge. Looking @ the year though, I unsure of the accuracy of the stock gauge. I know on the '87 to 96's, the stock gauge registers @ 7 psi, and that can be anywhere between "NORMAL" for the needle. Kemical, you may have to correct me for years prior to '87.
If this truck has a PCV, I'm sure it would, I would check the operation of it. Your leak may just be the engine "blowing" pressure thru the weakest parts it can relieve itself. Pull the PCV valve and shake it. If it doesn't rattle or is full of sludge and gunk, replace it. If this is the case, replace it with a Motorcraft PCV valve. Spend the few extra bucks for the OEM and not the "It looks and rattles the same" type. $8 bucks is well spent!
Hope this helps.
Hope this helps.
Twilight Fenrir
06-21-2017 04:27 PM
LeoJr
08-17-2016 05:41 AM
