weak clutch
Old Apr 13, 2011 | 09:03 PM
octaneforce's Avatar
octaneforce
weak clutch
i did my clutch about 18k miles ago and its already starting to slip again. i never slip my clutch, and ive always known how to drive a manual so its not like i learned on it. i think i ruined it by pulling my boat around. another possibility is that the pressure plate could be bad. the clutches on these 150s are weak links. is there a more aggressive clutch kit out there for these trucks? my local guy has the kit for like 90 bucks but i don't want to run into the same problem.
Old Apr 13, 2011 | 09:07 PM
SideWinder4.9l's Avatar
SideWinder4.9l
92 1992 Ford F150 Clutch Kit - Clutch - Sachs, Valeo, Centerforce - PartsGeek
Main bottom of the page.....I've dealt with PG for a long while...CHEAP S&H, prompt service.....Never had a issue with'em....
-Wes
Old Apr 13, 2011 | 09:14 PM
octaneforce
that centerforce clutch seems awesome. pricey but i bet it wont burn up like the one i have now. what size flywheel do these trucks have? the 150s have a 10 inch right? That centerforce clutch says its 11 inch, but it appears to fit my truck.
Old Apr 13, 2011 | 09:17 PM
SideWinder4.9l
They have more CF brand clutches somewhere....I foundem once....And yeah, the 150's have 10", for the 300 that is, the v-8's use the 11" cluch....Also, that centerforce clutch doesn't come with a throwout bearing....
Lastly, it says its a 10 spline, CHECK YOUR SPLINES BEFORE ordering.....Just a FYI there....
-Wes
P.S-I'm contemplating a Hurst shifter,and a Centerforce Clutch....
Old Apr 13, 2011 | 09:20 PM
octaneforce
ford really let down the 300 in the 150s. they are geared like a lincoln towncar and have the smallest flywheels. isnt the 300 supposed to be a pulling motor?!
Old Apr 13, 2011 | 09:27 PM
SideWinder4.9l
True....I can't imagine mine with a cam, 3.55 gears, a short throw kit and a TIGHT clutch.....
The Centerforce clearly say it's for eiter high Horsepower or High Torque apps......I gues I definantly aint in the high HP group
And yeah, the 300 a is a brutally slow pulling engine....The slower, less RPM's it can pull with, the better....But a tough as nails contender....
-Wes
