Ran great when parked!
Old Apr 13, 2011 | 08:14 PM
way2fast1's Avatar
way2fast1
Cool Ran great when parked!
Well this officially puts a dagger in my plans of driving this truck for at least a few years.
Found this when i pulled the inspection plate on the pan.
Old Apr 13, 2011 | 08:20 PM
ssj7kids's Avatar
ssj7kids
Yeah..... "stopped running, so it was parked"
Sorta my story.
But it's SO much more fun when your done.... (or so they tell me)
And we'll have so many more stories to tell....
Old Apr 13, 2011 | 08:25 PM
Mervy49's Avatar
Mervy49
What does the crank look like after that failure? Is it at all possible that you could just replace that rod and bearing and get it running again or did the rod exit through the block?
Old Apr 13, 2011 | 08:38 PM
way2fast1's Avatar
way2fast1
That's number 3 main cap. I got the motor to rotate freely and I can hear a clanking sound. i think the crank is broken. I am going to pull the pan this weekend and see for sure.
Old Apr 13, 2011 | 08:41 PM
Mervy49's Avatar
Mervy49
Owch... good luck, hope it's not too bad.
Old Apr 13, 2011 | 08:44 PM
mechmagcn's Avatar
mechmagcn
Uh.... that's not a rod! That's a main bearing cap. Don't think I've ever seen one broken like that.
Old Apr 13, 2011 | 08:54 PM
Old F1's Avatar
Old F1
The sooner the better,……..actually, with all the right groveling noises made towards the flatty guys,……cut your loses NOW, right NOW, do the 302 NOW! Unless you like being tortured indefinitely with questionable results and high costs?
All depends on time and money of course, the more money the faster it gets done.
This can be patched with used parts, as can the other things that might come up, the compression on that cylinder might be a little low with that big score in it though!
The 302 is realistically a year long project and many dollars no matter how it is done. It’s time for some soul searching because unfortunately the flatty could be just as bad time and money wise and then you might not be happy with something you can not drive on the freeway. Is it worth the gamble, only you can decide that, but you are going to have to make that decision NOW and live with whatever the consequences are?
Old Apr 13, 2011 | 09:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Stick a fork in it, that's done... The "drop in quick and cheaply" solution is a clean, used flat motor (6 or V8).
Old Apr 14, 2011 | 06:42 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Ooooh! wow, sorry, I don't have a cheap band-aid remedy for that one.
Bobby
Old Apr 14, 2011 | 04:18 PM
52 Merc's Avatar
52 Merc
I can't believe no one's offered the JB weld fix yet. Or, that'll buff right out. ;-)
Sorry for the bad luck. On the more positive side, if the rest of the block is still good, someone is bound to have a junk block with good main caps available. With a quick line bore and new main bearings, it could be good as new.
Old Apr 14, 2011 | 05:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm at a loss to understand how that got cracked. Installed without being seated correctly? Bolts not torqued? The block may be OK, caps can be interchanged. Crank is likely shot. But I know where you can get a couple of flatmotors:
https://www.ford-trucks.com/forums/1...ng-advice.html
Old Apr 14, 2011 | 06:12 PM
way2fast1's Avatar
way2fast1
about to go out, drop the pan with plans of pulling the engine this weekend. city motors in Dallas will vat, magnaflux the block for $45, they only charge $8 per hole to bore it. so I'm going to start there, see if the blocks good.
Thanks for all the input, pokes.
Old Apr 14, 2011 | 08:43 PM
Doc's Avatar
Doc
Man you are lucky. I'd probably have to drive at least 150 miles in any direction to get that done around here. I guess we now know why it was parked in 1964. I was just sitting here thinking. I wonder what percentage of the F1's were still on the road in 1964. And what percentage of those suffered engine failures like that during that time period. I make a mental note of the "family truck" stories that I hear on here. Seems like most of them involve somebody parking them in the late 70's, early 80's. It would be an interesting little poll to hear when a lot of our trucks were retired the first time around.
Old Apr 15, 2011 | 03:55 AM
55 f350's Avatar
55 f350
FTE Remembers
i was gonna ask if the block itself was still good / repairable . instead of digging for old cores for your crank and rods let me point you in the direction of socal speedshop in ca . they are selling nos flathead parts from the infamous french flatheads that vern tardel / sf flatheads manage to acquire . they will sell you a brand new crank for like 250 , and new rods for about 200 . a lot cheaper than scrounging for useable cores and machine work . take a look at their site and at sf flatheads . lots of drooly items if you wanna get silly and dig the old stuff ............................
Old Apr 15, 2011 | 01:12 PM
way2fast1's Avatar
way2fast1
yup cranks gone too.
Here's the crank. I'm guessing this is one of those custom two piece performance crankshafts.
