JP-8 Jet Fuel
Jet A is selling for $5.45 per gallon in Southern California today. JP8 is the military equivalent.
Why would you even ask about using jet fuel in your truck at this price level unless some of it fell off the tanker truck? Since you're asking about JP8, do you have "access" to a military fuel tanker?
Some very good information from the Army's experience using JP8 as diesel fuel is listed in http://www.almc.army.mil/alog/issues...3;reality.html.
Basically, lubricity issues at high temperarure is a problem. Low termperature operation is OK.
Lou Braun
Lou Braun
I may be crazy but i have heard everything the army has will run on JP8
JP-8 - Wikipedia, the free encyclopedia
When fuel is drained from civilian aircraft under some circumstances it is illegal to reuse for aviation, and lucky diesel owners who work at the right jobs can haul it off free to save HAZMAT fees. Otherwise it goes in the Safety-Kleen truck.
Check the powerstroke forums. Some folks run extra lube supplements or mix it with diesel.
It will work. I've done it. I would run it as a blend and not straight. I get mine from an airport also when they drain it from planes. I may be the wrong person to ask though because I've run liquified styrofoam peanuts through my 6.0 just to see what would happen. It's all just one big expieriment so I don't care.
Jet fuel is the same as kerosene. A diesel engine will run on jet fuel, kerosene, motor oil, and other things. Jet fuel and kerosene are basically the same as diesel fuel. But they lack any oil for lubrication of the fuel injectors. So you'll probably destroy the fuel injectors, and on an engine with a mechanical fuel pump, you'll wreck the pump.
BE VERY CAREFULL WITH JP-8 IT BURNS AT A HIGHER TEMP THAN THE PREVIOS JP-4 OR JET A. IF YOU GET SOME ON YOUR SKIN YOU FEEL A BURNING SENSATION UNLIKE JP-4. WHEN JP-8 FIRST CAME OUT THE ARMY AND AIRFORCE BOTH HAD PROBLEMS USING IT IN THEIR HUMVES,LIKE SOME ELSE SAID THE MELTED THE MOTORS ON A COUPLE UNITS. THE REASON THE MILITARY WENT TO JP-8 IS THE HIGHER FLASH PIONT,NOW IF YOU CAN GET AHOLD OF THE PLUS 100 ADDITIVE IT WOULD CLEAN UP YOUR FUEL SYSTEMBUT NOT SURE IF THE INJECTOR ORINGS WILL LAST AS THE STUFF IS REALLY HARD ON STUFF. SO YOU WORK AT LANGLEY OR KIRLAND I SEE. GOING TO KIRKLAND NEXT WEEK ,SEEMS THEY ARE MOVING ANOTHER BASE THEIR DUE TO THE BRAK SHUTDOWN.
JP-8 has a lower flashpoint than diesel at 100 deg. Diesel has a flashpoint of 143ish degrees. Jet-a is the civilian equivalent of jp-8. They went to jp-8 because it was less flammable and less hazardous. Flammability and flashpoint are two very different things. The biggest problem with JP-4 that warranted an upgrade was non conductive fuel and the fact that it could build up its own static electricity when being moved through pipes and tanks possibly cuasing itself to ignite.
This excerpt is taken from a de-classified AF technical order and has been used in places such as Wikipedia.org and other places.
"JP-8 (or Navy JP-5) is used as a fuel for aircraft, heaters, stoves, tanks and by the U.S. military as a replacement for diesel fuel in the engines of nearly all tactical ground vehicles and electrical generators, and as a coolant in engines and some other aircraft components. The use of a single fuel greatly simplifies logistics."
They didn't have problems with it melting engines but it does cause premature wear of HPOP, injectors and exhaust valve seats due to low sulphur content and undefined lubricity conditions. The 6.5L turbo GM diesel used in hummers was not really affected by the change but for one thing, under very cold conditions the trucks were hard to start and idled roughly until the combustion chambers were sufficently warmed. The 6.2L was uneffected by the fuel. It also doesn't gel at low temps.
