Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How to Change Brake Rotor
Step by step instructions for do-it-yourself repairs
- How To Replace Emergency Brake
Parking Brake Backing Plate Installation - WITH PICTURES
#91
Hmmmm
I did mine over the weekend and ran into a similar situation. I guess I didn't pay close attention to the direction of the parking brake hinged actuator(lever thingy) when removing it. After an hour or so of mother *****in it, the lever was removed and reversed 180 degrees and the shoes fit perfectly and the drum slid right on. Hope this helps. This job takes a lot of patience, so be prepared.
#93
#94
#95
Figured it out
So I had a second look at everything and it seems I did have the lever backwards. I followed everyone's pictures with the long channel end of the lever towards the caliper opening but mine must be opposite because I have the forward-of-axle caliper.
None of the pictures anyone has up allowed you to determine which diection the fat spring went so I ended up just putting it in so that the long part was on the side that seemed to need more room.
Normally this would have been much easier because you would take the stuff off and put it right back together but since I am rebuilding the axle I had it apart for a few weeks and all the info I could find basically just says put it back the way you found it!
#97
#99
#102
I hope this helps some one. I was originally told I couldn't buy this part on its own, that I had to buy a complete Ford brake kit, what ever that was.
Anyways, of course FTE gets it right
Thank you to 2000silverbullet for finding this item for me.
https://www.ford-trucks.com/forums/1...l#post12904441
Part# F81Z-2A637-AA
Good picture of it and the Ford part plastic packaging here -> Brand New Ford Parking Brake Boot F81Z 2A637 AA | eBay
Tousley has them for $21
Ford Parts - Tousley Ford Parts Depot
Part# F81Z-2A637-AA
#103
