Parking Brake Backing Plate Installation - WITH PICTURES
1 Attachment(s)
I am starting this thread to (hopefully) help other SD owners get their parking brakes to work again. I haven't been able to find a thread that takes you through this procedure in detail, so i will try to write one.
My parking brake never really worked right (wouldn't hold the truck, and once engaged it would not fully dis-engage), so i am going to take them apart and get them working again. Since i bought my truck used in the north east, it has a fair bit of rust cancer. Consequently i am suffering from the common "dust shield rot". In preparation of digging into them this weekend, i ordered dorman 924-212 dust shields (for my 2003my SRW). I ordered them from rock auto, and am so far impressed. They were only $50 shipped. Ordered them on tuesday morning and they were on my front porch when i got home from work today (thursday). This is actually a kit that includes both left and right dust shields, pins/clips, new adjustment hole dust plug and actuator boot. All in all, not a bad deal for $50 especially since the dealer only sells them as part of an "assembly" for upwards of $350 a side. Anyway, here is a pic: Attachment 202959 Stay tuned. The rest will follow this weekend. |
15 Attachment(s)
NOTE: Some parking brake shoes contain asbestos, take proper precautions.
Ok, finished installing the new backing plates and shoes today. Here is how i did it: Step 1: Chock the wheels. This is self explanatory, but make sure the parking brake is OFF. Attachment 202932 Step 2: Lift the wheel and set the axle on a jack stand. (never work on the jack) Attachment 202933 Step 3: Remove the wheel. 21mm socket Step 4: Remove the brake caliper. 18mm socket Either set it on something or use a ziptie or piece of wire to hang it from the leafspring. Do not let it dangle from the brake hose. Attachment 202934 Step 5: Remove the rotor and set aside. This might take some persuasion from a rubber mallet or dead blow hammer. If you use a steel hammer, make sure you protect the rotor with a piece of wood. http://i564.photobucket.com/albums/s...k/IMG_1960.jpg http://i564.photobucket.com/albums/s...k/IMG_1961.jpg Step 6: Remove all 8 bolts holding the axle in. 18mm socket Once the bolts are out, place a catch pan under the end of the axle because some oil will come out. Grab the plate at the end of the axle and pull the axle out. This might take a little effort to get past the o-ring, just be ready for it to let go. Attachment 202935 Attachment 202936 Step 7: Remove the spindle nut using a spindle nut socket. The 4 teeth on this socket engage the 4 notches in the nut. NOTE: the drivers side screws on/off backwards. Attachment 202937 Attachment 202938 Attachment 202939 Step 8: Using a 3-jaw puller, remove the hub. You will need a step plate, but since i didn't have one, i used the spindle socket by turning it around and placing it over the axle tube end. Be careful not to let the hub fall on the ground when it comes off. There is a set of bearings behind the spindle nut, don't drop those either as they will fall out of the hub if you turn it face down. EDIT(3/1/2012): Inspect the hub seals and replace if they have been damaged. Some people have noted that they can tear while pulling off the hub. This will expose the parking brake. I like to wrap the shiny part of the axle end in paper towels and tape it on to protect it and minimize cleanup later, especially if you have the kind of rust problem i have. Attachment 202940 Step 9: Remove the parking brake shoes. First remove the smaller-top spring. Then remove the bottom spring. Next remove the adjustment screw on the bottom... it just pulls away from the shoes when you pull them apart. Finally remove the left shoe by pulling it to the left (stretching the spring). Then work the right shoe free. If you are just replacing shoes, then you can skip to the re-assembly section, otherwise continue. Attachment 202941 Step 10: Remove the brake cable from the lever-thingy. Attachment 202942 Step 11: Remove the backing plate. 24mm socket Remove the 4 backing plate nuts. Some penitrating oil might help here. Tap on the bolts to break the backing plate assembly free of the axle. The bolts will stay stuck in the plate. http://i564.photobucket.com/albums/s...k/IMG_1983.jpg Step 12: Remove the bolts from the backing plate. Use a hammer to tap the bolts free of the plate, this is relatively easy and shouldn't take much effort. Just be careful not to damage the threads on the bolts. Attachment 202943 http://i564.photobucket.com/albums/s...k/IMG_1986.jpg Attachment 202944 At this point just clean up all the parts and pieces. I chose to use a pneumatic scaler to remove all the rust i could. I then cleaned the parts with brake cleaner and painted them with black rattle-can paint. I also had to work on the lever thingy to loosen it up. It was completely rusted and didn't articulate at all. Beating it up with the scaler and hammer did the trick. Lever thingy: Attachment 202945 Paint: Attachment 202946 |
4 Attachment(s)
Re-assembly is basically the same as the removal but in reverse.
Step 1: Install the new rubber boot for the lever thingy and the adjustment hole cover in the new backing plate. Sandwich the new backing plate between the bolts and the heavy steel plate. place this assembly on the axle and tighten the bolts. It will help the bolts catch if you tap them in a bit with a hammer from the outside. Attachment 202928 Things are starting to look better. Step 2: Install the brake lever thingy into the rubber boot. Make sure it articulates freely, this is key to the parking brake operation. If there is any resistance or grinding, make sure you clean it up with some emery paper. I also worked some axle grease into it then wiped off the excess. I didn't get a good picture of this during re-assembly, but it goes in this way: Attachment 202929 Step 3: Install the big spring into the upper-back side of both brake shoes. Put the right shoe in place first, then stretch the left shoe over the lever thingy. This might take some effort. Install the adjustment screw and the bottom spring. Install the pins and clips to hold the shoes in place. Finally, install the skinny top spring. Make sure you install it so the spring is up. Otherwise it will rub on the hub. Attachment 202930 Step 4: Install the brake cable end back into the lever thingy. Step 5: At this point you should roughly adjust the shoes to fit the rotor hat. It is much easier to do this now then to try to do it after everything is closed back up. If you don't have a parking break shoe gauge (i didn't) then I found it is easy enough to adjust the brake shoes until they just barely fit into the rotor hat. Keep sliding the rotor hat on then adjusting until the rotor just fits. Using this method, i didn't even have to re-adjust after my test drive. Step 6: Remove the protective towel and tape and slide the hub assembly (with bearings) back over the axle end. Just in case you dropped the bearings, they go on so the wedge shape is pointing at the truck. Thread on the spindle nut and tighten. ------EDITED------- If you are reusing bearings: Tighten to 60 lbft then back off 7 notches (or clicks). If you are using new bearings: Tighten to 60 lbft then back off 5 notches (or clicks). ------EDITED------- (thanks 99f350sd) Step 7: re-install the axle shaft: I squirted a bunch of rear diff fluid in before i closed it up to give it some lubrication until some fluid gets a chance to flow in there. Attachment 202931 Step 8: Re install the 8 axle bolts and tighten to 80 lbft Step 9: Re install the rotor Step 10: Re install the caliper Step 11: Re install the wheel Step 12: Take for a test drive and adjust parking brakes as needed. |
awesome write up gunnerdog and nice job on the pics, going in my favorites for future use,:-drink
Awesome write up!!!!! Reps on the way!!
Subscribing to keep track of this thread for when that day comes for me. Thanks for taking the time to document this with the pics and info! :-X22 |
Excellent write-up and pictures. It's these type of things that give me the confidence to tackle larger projects for myself. The moment I read something that said "remove axle" I would have closed the book. Seeing your pictures with your 12-steps makes it seem less daunting. Thank you for sharing.
This is great ,thanks ,now it doesn't look very difficult at all.
Rep's given. Thanks again. |
I am also subscribing for future use. Thanks for the writeup.
Regards, Russ |
Reps sent.
Thanks for the reps!!
Glad i can give back something to the FTE. :-X25 |
Added to the tech folder - GREAT WORK GUNNERDOG :-X22
Boy, those backing plates were AWFUL! |
Thanks for the write-up GUNNERDOG!:-X22
And thanks for adding it to the Tech Folder, Art.:-X22 This is exactly the type of info that folks are looking for often times when visiting the site. |
Originally Posted by Krewat
(Post 10237611)
Funny how you happen to do this at this particular time. I ordered the assemblys from FordGuyEd and they just arrived yesterday. The total came out to $452.00 with shipping. They are rather impressive looking and come fully assembled. Thanks again!!!!!!! |
Originally Posted by GUNNERDOG
(Post 10234680)
