Runaway engine situation under load
Old Apr 17, 2011 | 09:41 PM
  #31
Otahyoni's Avatar
Otahyoni
Blue, what makes me doubt that is the fact that it stops surging instantly when i turn the cold timing advance off.....
It's probably timing... havent had time to have it properly timed, just done it by ear...
Old Apr 17, 2011 | 10:54 PM
  #32
doube_zero's Avatar
doube_zero
i don't understand about the timing. I've replaced my pump before never even occured to me about any kind of timing, and I've never had any troubles with running or hauling. Ole betsie runs slick as a whistle.
Old Apr 20, 2011 | 10:07 PM
  #33
BlueOvalBud's Avatar
BlueOvalBud
Timing isn't a big deal to get the truck started. I've had a few different IP's on this engine and I've swapped them enough times to know that it will defeintly run fine no matter if the pump has the marks lined up or if the pump is about a dime's width advanced.
I don't even remember where my current pump is... I seem to think it's a dime's width advanced, but all the other pumps I just lined up the marks and called it good.
This is the first time I've had an issue with surging with the different IP and Injector combo's.
As an update, my truck is running like a raped ape...the thing is back to Rocket Status.
I'm 99% sure my problem was an air intrusion issue where I was sucking air on the supply line. It doesn't make much sense to me why the truck would stall... BUT, I did each fix one at a time to diagnose the issue and the surging immediately went away after by-passing the selector valve.
Otahyoni, air intrusion doesn't sound like your problem if the issue goes away after shutting the cold advance off. I'm still thinking about yours, and I'm coming up empty...
6Fastback7
1978 - 1996 Big Bronco
Aug 8, 2013 07:48 AM
Dtmaster2008
May 11, 2013 04:51 PM
BlueOvalBud
Jan 11, 2011 01:45 AM
HD Rider
Apr 9, 2010 06:53 AM
wayfastwhitey
Jul 18, 2005 10:29 PM
