update with pics
Old Apr 13, 2011 | 01:13 PM
low54's Avatar
low54
update with pics
Hi All,
its been awhile since i've been on here...School, baby on the way, etc...however, there's been several nice days where i've gotten out to work on the '54...i originally had bought 8 inch rear wheels from wheel vintques...the back space was 3 3/4. I should have went with 4inch backspace...cause as you will see in the first set of pics my 265/75R15's just didn't sit or look right...YES! i could compensate with fairlane fenders but I just dont have the $$...take a looksee... and you'll see
with the 265's
and from the rear...
So, I went out and got 245/75R15's for the rear and I think they will work...I however need to modify the fenders a little...I'm working on a post that shows my plans...here is how the truck sits now...
The fenders are in bad shape around the bottoms, i'm going to fab some patches...more to come
Old Apr 13, 2011 | 01:32 PM
tinman52's Avatar
tinman52
Welder User
Love the stance.......too bad about the wheels. Which rear end are you running?
Old Apr 13, 2011 | 01:53 PM
low54's Avatar
low54
I'm running a 9inch with posi and 3.50 gearing out of a '67 1/2 ton Ford it bolted right in...it was the same length as the dana44....
Old Apr 13, 2011 | 02:38 PM
Layed Out 100's Avatar
Layed Out 100
looking good, what you doing to the fenders?
Old Apr 13, 2011 | 02:50 PM
low54's Avatar
low54
I'm going to try and flar them about an 8th of an inch...
Old Apr 13, 2011 | 03:37 PM
Layed Out 100
sounds possible, Im wanting to stretch mine up for more (rear tire) clearance without changing the wheel opening......like cut them horizonal and add a two inch strip. think I may have to take mine to a good body shop to get them done. keep us posted and good luck
Old Apr 13, 2011 | 05:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might be better off trading those wheels to someone running the wider fenders, it still looks real tight. The rear axle can move sideways a fair amount, unless you put in a panhard rod.
Red Ford Truck
Ontario Chapter
39
Oct 26, 2012 06:36 PM
Roller150
Jan 4, 2011 07:13 AM
thepitshop
22
Nov 17, 2010 12:17 PM
ech0sh4y
2004 - 2008 F150
21
Nov 15, 2007 07:18 PM
993/4ton
Feb 20, 2007 01:28 PM
