Header question.
Old Apr 12, 2011 | 09:25 PM
Melbatoast's Avatar
Melbatoast
Header question.
Ok here is the skinny for those that don't know. I have a 76 f-150 4x4 with a 390 and an automatic. I am installing headers (flowtech), long tube. And was wondering If anyone else has gone through this. I have always ran chevys cause parts were cheap. And everyone I know has chevy's. So parts are everywhere for me.
But My old man was a ford man. And I saw the light through Lincolns, the mark 8 to be specific.
I have to pull the motor mount out of the passenger side to install the header. And was wondering if these headers will clear the factory starter? I am also wondering what the torque specs are. Maybe I should read the paperwork that came with them.
Old Apr 12, 2011 | 11:33 PM
co425's Avatar
co425
Nope. You have to pull the starter and the passenger motor mount and motor mount stand. My flowtechs also hit the oil pan. I also had to cut the passenger side flange in half. Not a great recipe for a good sealing set of headers. I will never buy that brand again. Make sure you use anti sieze on the bolts.
Old Apr 13, 2011 | 02:55 AM
7Ford6's Avatar
7Ford6
I have the same truck.. Started with 18 Gauge Headmans (Rusted Thru) and Just Replaced those with thicker 16 Gauge Hookers.. I eventually replaced the heat wrapped stock starter with a mini re-using the same heat wrap I used trying to prolong the stock starters life... Gets real hot right there close to the tubes... With out looking it up, I think the torque on the bolts was like 13 or so foot pounds.. Whatever it was, I torqued them to the stock manifold spec in the book.... some of the lower bolts I was never able to use a torque wrench, only hand tight.. A real P.I.T.A. job if you ask me..
Old Apr 13, 2011 | 08:30 PM
Melbatoast's Avatar
Melbatoast
I can't for the life of me figure out why you would have to remove all that shat. I think if I lift the motor enough and pull the motor mount out I will have enough room to put it through. And I can't figure out why I should cut it.
I did finally read the instructions that came with them. And yes I read the cut it part. I don't like that, but don't see it necessary to do.
Thank you for a lead on the torque spec. And I forgot to put antiseize on them so I will be heading back to the truck soon. And doing that.
Old Apr 13, 2011 | 09:06 PM
co425's Avatar
co425
You dont have to remove the pan. My headers just hit them. You can get the pass header in if you lift the motor off of the shell and remove the rubber mount. I still had to cut the flange though. It may be a different situation on a f250 4x4. I figured it would be the same on your f150.
Old Apr 13, 2011 | 09:21 PM
Melbatoast's Avatar
Melbatoast
Why did you have to cut the flange exactly? And I definitely Have done headers enough on other things to know I shouldn't pull the pan.
If I have to I will yank the whole damn motor. That would be a little extreme, I know. But I really don't see it coming to that. And I really don't know why I need to cut it.
Old Apr 14, 2011 | 01:52 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Why didn't you just get some fenderwell exit header's and have alot better time putting them on?
Never again will I run inside the frame type headers or cheap ones either for all the above statements.
Old Apr 14, 2011 | 07:55 AM
7Ford6's Avatar
7Ford6
I'm to lazy to search for the post but, someone else posted in the last few months that they had installed the Flowtech Headers and the passengers side slipped in easily in two pieces once that flange was cut... Look at the pipes, they should slide apart in two pieces according to the post I read.... Look for missing welds around the pipes...
EDIT - Found the thread - https://www.ford-trucks.com/forums/1...0-headers.html
Old Apr 14, 2011 | 04:24 PM
Melbatoast's Avatar
Melbatoast
That thread was very helpful. I don't know how many times I had the header in my hands and didn't see the split in the primary tube.
wb6anp
S. California Chapter
May 16, 2009 11:13 AM
BigBad352
Dec 22, 2008 09:41 PM
frdmike
Exhaust Systems
16
Oct 27, 2005 12:08 AM
Bananarama
Modular V10 (6.8l)
24
Jul 14, 2005 09:56 PM
ions664x4
19
Apr 20, 2002 02:52 PM
