Window Lock Switch Problem
Old Apr 12, 2011 | 07:29 PM
bearabledust's Avatar
bearabledust
Hello all, I have an 06 SCrew that is acting like the window lock is on. I can operate all the windows by the master (driver's) switch, but they won't work from any of the other positions.
I have tried 2 new driver's switch assemblies and a new relay with no luck.
I tried my switch and relay in another truck and it works just fine.
Any suggestions?
Thanks,
Dayne
Old Apr 22, 2011 | 06:40 PM
bearabledust
Anybody? It looks like I need to start chasing wires. Any thoughts on where to start?
Old Apr 22, 2011 | 07:16 PM
HomerWinzlow's Avatar
HomerWinzlow
First you should pull the passenger front switch and see if it is even getting power from the master switch. If not you probably have a broken wire in the door opening boot at the driver door switch. If you are getting power then see if the switch is passing power to the other pins in the up and down position. I have seen all the passenger door switches bad at one time before.
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
Dozier
2004 - 2008 F150
Jun 27, 2014 11:28 AM
F-250beast
Nov 25, 2013 05:11 PM
synvolk
1997 - 2003 F150
Mar 14, 2013 03:35 PM
pablocruz69
Mar 28, 2009 11:44 AM
