There were very slight changes (taillights, rear disc brakes) in the 04-05 models but the wheel size/offset is the same.
The alloys should be a 16x6.5 or 7 (can't remember right off) wit ha 235-70-16 tire. I know you could upgrade the steel wheels for alloy at the dealer which should mean the offset would be correct and you should not have any rubbing. Now if the overall height is different the speedo will be off. You can use this site to check the amount it is off: DML Tire and Wheel Calculator
