egr
Old Apr 12, 2011 | 10:54 AM
cpettymore7777's Avatar
cpettymore7777
egr
when my truck warms up it has a high idle until i turn it off and back on again. i replaced the iac. i was thinking the egr is hanging up. if i disconnect the vac line to the egr and drive it for awhile will it do any damage since it should stay closed all the time
Old Apr 12, 2011 | 12:25 PM
rla2005's Avatar
rla2005
There is no harm in disconnecting the EGR for a short term test. Personally I think your issue is the TPS, but if you want to test the EGR theory, it's worth a shot.
Old Apr 19, 2011 | 02:02 PM
cpettymore7777
well, the egr seemed to be causing my stumbling problem. i put a new map in it and the idle seemed to be good now, we will see. i just dont feel like pulling the throttle body to get to the tps. if it acts up again i have no choice
Old Apr 19, 2011 | 03:14 PM
SideWinder4.9l's Avatar
SideWinder4.9l
TPS should be on the side of the throttle body.....With 3 (IIRC) wires coming out of it...
Old Apr 19, 2011 | 03:37 PM
rla2005's Avatar
rla2005
It's on the bottom of the throttle body on the 5.0/5.8L engines.
courtesy of subford
