I did not think Ford offers the V-10 in any model, and I think the PSD is standard on the F-450, as well as being a dully. It also must come as a crew cab.
I think the V-10 is available for chassis cabs only.
Yes, it works but above a certain speed it disengages, not a good thing if you are towing uphill on slick roads. I have tried it out and it just isn't comparable to limited slip. I find the rear of truck slips side to side with the electronic locker engaged in the same scenario. I was forced to shift into 4 wd to keep things tracking straight.
If you are towing up a hill and the roads are slick.....SLOW DOWN!!!
Before you go on ranting about the differential, get some decent tires. You can put the best lockers or limited slip differentials on your truck, but if your tires are cr@p it won't make any difference. It is all a waste of money unless you can grip the road surface/
If you are towing up a hill and the road is snow or ice covered, slick enough to get yourself out of shape, this would be a severe condition which will require the driver to do something.
1. Traction control will get you through.
2. 4 wheel high would probably be the best option if you don't have traction control.
3. The ELD will lock the rear diff, and if traction is not good, you will spin both rear tires. The ELD works, evidence is when you look in the mirrors and see your wheels spinning. That's all it can do.
4. 4 wheel high combined with the traction control will get you up a hill if it is passable. I think turning traction control off would get you up the hill faster but you better hold on and correct for some side spin.
yup thats how a locker works, we have posi in the truck we haul cattle with and if you try to go on a side hill being both tires are spinning all the time the back tends to slide down the hill, limited slip will not because in a situation like this 1 tire will be doing most of the work and you will stay straight. I guess I dont know what you where expecting thats just how a locked rearend acts, its better for rough terrian where 1 wheel might come off a little the other one will still have power to it, it is not a plus on ice the way see it.
Yes, and the V10 is only available on the F450/F550 chassis cabs. (besides vans & stripped chassis) My 2011 F550 is a V10. The F350 Cab & Chassis comes with the 6.2 as the only gas engine.
I dont know about you guys but im 40 and have over a million miles in my pick up trucks hauling things, and when I come to a grade with snow or ice on it I go faster and use momentum, skill and every feature that truck has to get over the top.
My 11 250 SD has a ton of cup holders... four alone in the front, for only two passengers. I'd send you a few if I could.
They took the cup holders from their trucks and put it on ours. I've never seen a vehicle with as much cab storage as the 2011 SD with the center console!
My only complaint from my 2006 to my 2011 is that they moved the backup sensor kill button from the dash to the info screen/steering wheel menu system
But why not put a "backup" sensor on the front also? I don't understand that.
My Armada has them front and back and it's a life saver. When parking, you can't tell how close the front of the truck is from the car in front of you. As long as the truck is, you need to pull all the way in.
Take a chill pill friend. We use studded snow treads here. I've been doing this for 45 years so I have a clue about what I'm talking about. Instead of going off on your own rant, stay on the subject or stay off this forum.
This may be the start of a new thread, but the front end sensor and a couple of other things would be great options that I think that would be good to have available over the 2011 options list. In addition to the manual sensor silence switch, how about a prewired socket on or near the roof for plugging in beacon lights, maybe using one of the up-fitter switches to control it. Another would be to include the tailgate lock in the electric locking system, and a third would be some sort of hide-away swing-out side bed steps in front of the rear wheel.
Not sure who you are referring to, but the title of this thread is "2011 Super - Duty Letdown", which appears to be referring to multiple things that the OP was unhappy about with the 2011 model, not specifically about how to drive up a hill in the snow.
You are right on the money. Slowing down is the worse thing to do, especially when towing. Any long-haul driver in mountainous snow country can attest to this.
