I-Beam Ford
Old Dec 20, 2002 | 10:48 PM
TryMe's Avatar
TryMe
I-Beam Ford
This may sound weird. But has anyone ever narrowed the front width of a I-beam Ford truck? I like to narrow the front axle ( which is I-beams) about four inches total. Or two inches each side. I'm not talking about cutting and welding the I-beams,I know its wrong and should not be done. But I have thought about changing were the I-beams mount. to further in. I thing It could be done. But the Coil springs won't let me. One person said do away with the original coil springs move the mounts,then ad air bags to the I-beams but on the inside of the frame.Ya ! Any Ideas ??????
Old Dec 20, 2002 | 10:59 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I-Beam Ford
Maybe you could convert to a single solid front axle, like the one-tons, then you could have the housing and shafts made to whatever length you want, as long as you have enough room to mount the springs. I have heard of people converting I-Beam F250's to solid axle 'monobeam' frontend before. Im curious as to why you want to narrow the front axle?
Old Dec 20, 2002 | 11:22 PM
steve83's Avatar
steve83
I-Beam Ford
Yeah, why? You'd lose some serious steering angle; the shocks wouldn't mount; you'd have to redesign the steering linkage; you'd have MUCH more sway; and you'd also have to cut down the R axleshaft 4".
Old Dec 21, 2002 | 05:21 PM
TryMe's Avatar
TryMe
I-Beam Ford
The I-beam front is under a early model ford. It does not reall look bad,but the front wheels and tires are about even with the edge of the fenders. Just figured if it could be done,the wheels would look better a little more under the front fenders. Well thats for the reply.
Happy Holidays :-X12
Old Dec 21, 2002 | 08:25 PM
91f250460's Avatar
91f250460
I-Beam Ford
Couldn't you get rims with a different offset that would tuck the wheel/tire combo further inside the fender to accomplish the same thing but maintain ride quality.
T. Roberts
UFD Local 1147
Old Dec 22, 2002 | 01:49 PM
mooktank's Avatar
mooktank
I-Beam Ford
you could always get fender flares.
Old Dec 22, 2002 | 03:23 PM
TryMe's Avatar
TryMe
I-Beam Ford
I know I could get fender flairs. They look ok on late model trucks. But not on one thats over 50 years old.
Old Dec 22, 2002 | 03:47 PM
Hit Man X's Avatar
Hit Man X
I-Beam Ford
slamed150
Jan 4, 2013 07:19 AM
79 f-150 guy
Jan 3, 2011 02:36 PM
Windsor84
Sep 19, 2005 12:50 PM
DrewV
26
Apr 18, 2005 12:59 PM
loudfords
Jul 25, 2002 05:42 AM
