Sponsored by: Real Truck
Transmision, Speedometer, ABS Light...Big Problem?!?!
Old Apr 11, 2011 | 05:52 AM
Stone Mathews's Avatar
Stone Mathews
I was hauling my boat down the interstate last night, cruise control on ~70mph. Then, my cruise control suddenly kicks off, and when I glance down at the dash I notice my ABS light has come on.
The truck felt 100% normal to me, so I put it back on cruise and kept trucking to the next exit ramp just to check things out. All the breaking seemed normal (Breaks not sticking, no hot rotors, everything seems really normal. All fluids, break, tranny, oil, normal.)
So, I pull out towards the on ramp to continue heading home and I notice the following:
  • Speedometer does not work in 1st and/or 2nd gear. Then, during the shift from 2nd to 3rd gear it jumps up from 0mph to 35mph and begins to work fine from there on out.
  • Shifting from 1st to 2nd is very rough, but it does shift, it's just jerky. Much less so when I "ease it" through the rpms, more so when I just step on it.
  • Other than the ABS light being on, the shift from 1st-2nd being rough, and the speedo not working until I'm ~35mph and shifting from 2nd-3rd, the truck seems completely normal.
  • The Speedo/1st-2nd gear issue is completely repeatable.
  • Oh, and the ABS light is staying on...
This is either going to be a simple sensor failure, or a cratered/cratering transmission...lay it on my fellas, I can take it.
Stone
Old Apr 11, 2011 | 08:45 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Check the VSS (vehicle speed sensor) on top of the rear end. Napa calls this the ABS sensor. Take the connection off and clean, if that don't work, get another sensor. Good luck.
Old Apr 11, 2011 | 09:30 AM
sesh1975's Avatar
sesh1975
You lost your speed sensor. Its cheap enough to replace and very easy as it is located in your rear diff. Right on top. Pick up a new one and you will be good to go.
Old Apr 22, 2011 | 12:28 PM
Stone Mathews
Bingo!! We have a winner!
Thanks guys. That was exactly my problem. A $24 sensor, and she's back to her old self.
(Note to all 1999.0 model owners....I went through three different sensors at NAPA before I found the right one. Take your old one in. It was not listed under VSS or any other transmission sensors (they will ask you "14 or 20 transmission pan bolts?", it does not matter) the part you need is listed under the breaks category. This might be obvious to many, but it was not to me, or my two local NAPA dealers.)
Thanks again Miller and Sesh, reps given.
Stone
Old Apr 25, 2011 | 08:58 AM
miller_feed
Glad it was an easy fix. Thanks for letting us know.
1998F250SC
1997 - 2003 F150
Sep 2, 2016 03:55 PM
annaleigh
Nov 11, 2015 11:57 PM
boojumm
Dec 26, 2014 07:21 AM
Jerry Oren
1997 - 2003 F150
May 15, 2014 09:18 PM
codylt1
Nov 15, 2010 07:39 PM
