Sct info
Old Apr 10, 2011 | 07:23 PM
johnthoms's Avatar
johnthoms
Sct info
Hello fte. Can any body give me any instructions on the new sct fitting kit from ford I am a little confused about kit and the plate used for alignment and the bolts that came with the kit,also any info for me to do the whole job would be great thanks
Old Apr 10, 2011 | 07:55 PM
429poweredf350's Avatar
429poweredf350
John, check out this thread. https://www.ford-trucks.com/forums/1...tud-job-2.html
I just upgraded my STC fitting and there are some pictures of the old push together fitting as well as the new one. The plate and nylon bolts are used to properly align the new fitting. while you tighten it down before reinstalling the HPOP. Hope it helps.
Old Apr 10, 2011 | 08:23 PM
johnthoms's Avatar
johnthoms
Thanks, great pics where would u recommend I get a service manual there's a lot coming off engine and I just want to have proper info at had just in case of a brain fart
Old Apr 10, 2011 | 08:29 PM
johnthoms's Avatar
johnthoms
Also just have to ask about standpipes and dummy plugs anything important that I should know about doing them or are they self explanatory p.s. Gorgeous trucks mine is 06 also probably going with Bpd egr cooler while in this deep thanks
Old Apr 10, 2011 | 08:44 PM
429poweredf350
I got my service manual on Ebay. Kinda pricey but if you're going to work on your own truck, well worth the $. This site is invaluable if you're working on your own truck. If you're just doing the STC, you won't have to get into the high pressure oil rail or the stand pipes.
Old Apr 10, 2011 | 09:13 PM
johnthoms's Avatar
johnthoms
I ll check eBay for manual I really need one since I do most work myself now. I bought standpipes anyway for a just in case situation since Its easy with most stuff out of the way, trying to get that same feeling of confidence back after string of problems I love my truck to much to have that " I HOPE we get there" feeling
Old Apr 11, 2011 | 12:45 AM
smokersteve's Avatar
smokersteve
Here are some links to help with the work.
https://www.ford-trucks.com/ford-man...%20removal.pdf
Diesel Technician Society
This is the one piece, the better choice that the other update. But both are good.
Old Apr 11, 2011 | 07:17 PM
johnthoms's Avatar
johnthoms
Smokersteve thanks for links ,again fte is just great and everybody seems like we are all on the same team just trying to get the most out of ford trucks (and cars) once again thanks so much
Old Apr 11, 2011 | 07:26 PM
johnthoms's Avatar
johnthoms
Good evening fte, is there any type of alignment of Hpop when I go to remove and reinstall pump (marking compound or such) to check gear mesh or does the pump bolt in place with no need to worry thanks
Hotwheelbill
Jan 19, 2014 08:11 AM
southbound35west
May 23, 2011 01:11 PM
xpetom
Nov 14, 2010 11:17 AM
