1951-52 volare frame draft template
Old Apr 10, 2011 | 06:24 PM
iwanaflattie's Avatar
iwanaflattie
Hello gang i need the template to cut my frame for the volare.
I just bought a plasma cutter and im ready to play with it,
I will pay for your time and materials.
i prefer to get a print out since i dont have a big printer and dont know anyone in town with one.
Thanks.
Seth
Old Apr 11, 2011 | 07:38 AM
jimprowse's Avatar
jimprowse
volare installation
I'm also going to undertake a similar swap , "soon" , , there are several articles in FTEF ,maybe some in H A M B , as well ,,,, note that 48/52 is a bit narowwer than the 53/56 , but again , some mention is made of the differences , do you have the No Limit engineering D V D ? , it's a good help ,,,,, for templates , i was able to get a set from John Niolon , he has done quite a few , and has a number of threads , might try him , and i got a set from , either Bob's ,, or Bobco , , hope this helps , and i hope you will let everybody know how you made out , any tips/tricks/cautions etc , we can all learn fron what others do ,,,,, good luck ,,,, Jim Prowse ..
Old Apr 11, 2011 | 08:08 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Thanks.
Seth
I not sure anyone makes templates specifically for the 48-52 trucks. Here's a picture of the pieces of frame I cut out of my 49 when I notched it for the Volare. I kept them in one piece so that I could use them as a pattern if I decide to do another truck. Of course, this is only a starting place. After these notches you still have a bit of trimming to do. Maybe this picture will help...
Old Apr 11, 2011 | 08:16 AM
sdetweil's Avatar
sdetweil
I got mine from John as well. but can get copies if people need them
postage and copy is $7 cause of the drawing size.
sam
Old Apr 11, 2011 | 08:17 AM
iwanaflattie
my frame is a 51 Sam
Old Apr 11, 2011 | 08:22 AM
sdetweil's Avatar
sdetweil
yeh, I know.. the sides are gonna be the same..
see John's doc on the install with my pics of the templates installed
NOTES ON A VOLARE FRONT CLIP INSTALL
Sam
Old Apr 11, 2011 | 08:25 AM
iwanaflattie
I read the entire thing and I am ready to read it again.
Its an awesome write up.
So Sam, you are saying to use mt old frame to get the measurements to center it and use your pattern to do the rest.????
Old Apr 11, 2011 | 08:31 AM
sdetweil's Avatar
sdetweil
hm.. you are right, that extra narrow will change the specifics of the cut.
what is the frame width difference?
Sam
Old Apr 11, 2011 | 08:36 AM
iwanaflattie
i can measure mine later
Old Apr 11, 2011 | 09:59 AM
gdub's Avatar
gdub
Heres how I cut mine. The cut is level with the frame, centerline is 1" forward. I don't know that a template is really all that helpful on the F-1.
Old Apr 3, 2014 | 07:34 AM
1956in1956's Avatar
1956in1956
Hello Guys
Does anyone have Volare templates for a 56 F100 they are willing to share?
Decided to go with the Volare style clip on my 56.
Thanks ken
Winnipeg/Man
Old Apr 7, 2014 | 01:49 PM
jimprowse's Avatar
jimprowse
volare install
I don't have useable templates ,,, but as i found , you really don't need them .. if you'v read , and re-read the John Niolin info , it really helps .
I do have the NO LIMITS tech-talk DVD , that i'd gladly loan you ,,,
My install was on a "bare-frame 48 F1" ,,,,
Do , as is suggested by many ,, move the Volare 1 inch , to better centre it up ,,,, i went 1.5 inches , wish i hadn't ,,,,
do consider "offsetting" whatever powertrain to the right an inch or two ,,makes life a whole lot easier on the left side ,
good luck , you won't be sorry you did the swap ,,,,, jim prowse ..
ccaappyy
Jul 1, 2016 09:55 PM
CharlieLed
Nov 4, 2013 09:23 AM
blackhawkman
39
Jan 5, 2013 07:42 PM
nightmare10
15
Dec 26, 2011 10:33 PM
CIAF
22
Nov 10, 2005 11:30 AM
