Gearhead Automotive tunes...WOW
#46
#47
#48
perhaps it changed.....when I was talking to Matt he quoted me the tuner with his three tune package for 490.00 and that was last month....so I agree to disagree with you. 337.00 no tax and free ship + 100.00 for tunes is still cheaper than 490.00 that he quoted me last month. Just sayin.....this is the email:
$490 shipped to the 48 US states
Matt Robinson
Gearhead Automotive Performance
979-703-7338
gearheadautomotiveperformance
Matt Robinson
979-703-7338
#49
#50
What is the difference between the SF3 and the X3? IIRC my X3 was $425 with tunes but that wasn't from Matt.
#51
#53
#54
#55
Fellas,
I have also been using Matt's SRL+ & SRL tunes. These are by far the best I've tried yet. I agree with what everyone has said.
However, the only issue that I am having is with fuel economy. I am seeing a significant drop in mpg. I am getting about 3.5-4 mpg less with the SRL tunes than I am with IND's race tune. I spoke with Matt about it (excellent customer service by the way) and he thinks it may be from too much boost...we are currently trying to work it out.
Has anyone else noticed a drop in mpg? What are yalls boost levels at cruising speed/no load. I see around 8-10 PSi, this is higher when compared to IND's race tune. As I mentioned matt's tunes blow all others out of the water, just if i could get that mpg back up where IND has it...i will be one happy boy.
Thanks, any thloughts?
#57
jayybird,
when i started running matts tunes and once i relearned the truck, i got a raise in mpg about 3 mpg. this is hand calc and also filling tank to the rim at fill up. at crusing around 50mph or so with no load in running 2-5psi boost. i dont know if that is normal or not but i think it is.
also you are very very correct, (excellent customer service by the way). i had some issues when i got mine... when i loaded into the truck the truck would not crank. no starter, no wait to start light or nothing. i emailed him and he found out after some investigating there sct was having issues with the program that matt uses to build the tune. once he got it fixed he emailed me the new one and i have been in love with my truck ever sence.
#58
#59
Slightly off topic with a random SCT question. I'm in the middle of a BulletProof job on my '04 and am thinking about replacing my Predator with a SF3 since I hear so much good about them. I have 37" tires and see that the SF3 will allow for tire size changes. Do you do that separately from Matt's tunes or does it have to be custom-programmed into the tune file itself? Just wondering if there is a separate function for that.
Thanks...
Thanks...
#60
Thanks...
Thanks...
FYI--the most accurate way is to measure one rotation of your individual tire on the ground and hand calculate rotations per mile. Since they come in increments of 5 on the tuner I always pick the higher rotation figure to allow for tire wear. Seems to me that the hand calc'd figure is always different from what the tire manufacturers list on their websites.
