Help
Old Apr 9, 2011 | 11:02 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
Help
Hey guys,
I know I haven't been around much lately but I am in a bind and could really use some help.
My speedo stopped working the other day and at the same time the fuel gauge needle went up past the full mark.
I think the fuel tank selector valve is not working either but not 100% on that.
As a result the E4od has gone into limp mode and is hard shifting and the like.
I get the feeling like it is a power supply to these systems or perhaps a bad ground in that area.
I guess my question is have any of you guys had this problem or does anyone know where I would be best off starting with my fault finding.
Old Apr 9, 2011 | 11:33 AM
ADTMan's Avatar
ADTMan
Could the wiring cluster in the steering column affect that. My turn signal switch was acting up and all sorts of crazy things started happening to my truck. Mine is a 5 spd so I don't know of any affects on transmission. I replaced that multi-switch which was included the turn signals as well. It seems the turn signal switch affects several things. I doubt this is your issue but I though I would at least throw in my $.02 worth of knowledge....LOL
Good luck! I am sure someone else on here is going to be more helpful.
Old Apr 9, 2011 | 11:39 AM
WEST AUSSIE 94 250
Well funny you should say that because I recently had the steering column out of the truck.
It was a couple of weeks ago but I coiuld have loosened or bumped something.
Old Apr 9, 2011 | 11:42 AM
Dark Horse's Avatar
Dark Horse
I would check fuses first if their ok see if you have Brake lights others have posted that can cause problems with the tranny .
Old Apr 9, 2011 | 12:01 PM
WEST AUSSIE 94 250
really, a guy told me tonight that my tail lights where out. Could this all be conected?
Old Apr 9, 2011 | 09:58 PM
ADTMan's Avatar
ADTMan
The switch in the column does affect brake lights as well. That is what started me on my journey of replacing it. It is tied to the light switch too.
Old Apr 9, 2011 | 10:32 PM
84-6.9L's Avatar
84-6.9L
What about the relay on the back of the cluster? it may have some issues
Old Apr 10, 2011 | 11:51 AM
WEST AUSSIE 94 250
So I take it the general concensus is to start in and around the instrument cluster and associated wiring?
Old Apr 10, 2011 | 01:12 PM
Dark Horse's Avatar
Dark Horse
yes especially since you have had it apart recently something may not have been plugged completely in it would work at first but worked loose with vibration that happened to me last year I had hi beam head lights, turn signals, and em flashers, but no lo beam head lights no brake lights or tail lights. I found a plug in the steering column that was loose I squeezed it together and every thing started working again.
Eddie06f350Harley
Dec 4, 2013 06:21 PM
oubegood
Jul 2, 2010 10:49 AM
1978fordf250
16
Jun 25, 2006 06:01 AM
56frdf100
May 14, 2002 11:44 PM
