'88 Ranger upper manifold
Old Apr 8, 2011 | 10:29 AM
herby666's Avatar
herby666
I found out that the hose comes out of the vacuum tap at the upper manifold of my 2.9L EFI engine. But still I do not know where the other end of the hose belongs to...
What else could be the problem, that my Ranger does not run in the idle after the winter breake?
Still I did not find a way to put a picture of the hose here in the forum.
Bye - Herby Germany
Old Apr 8, 2011 | 06:16 PM
xlt4wd90's Avatar
xlt4wd90
There are a number of things that use vacuum from the engine, and some could be sensors. If at first you can not find where that vacuum hose goes to, try plugging it. At least that should let the engine run better. Do you know the general vicinity of the loose end of the hose when you first found it?
If you can't post pictures in this forum, can you post your picture some place else, and then provide a link to it here?
Old May 1, 2011 | 11:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Is this the vacuum tap at the rear of the manifold or near the TB? At the rear of my 87 2.9 the 2 larger ports are plugged.
Actually when I first got the truck one port was used for a goofy JC Whitney style cruise control unit.
Josh
laxxx
13
May 22, 2022 01:44 PM
1972Herbie
Oct 20, 2015 12:31 PM
clintusaf
Oct 4, 2015 03:44 AM
CH Jackson
Jul 29, 2015 05:13 PM
1972Herbie
Jan 27, 2015 07:51 AM
