Does not start now? Grr.
Old Apr 7, 2011 | 01:25 PM
JoeKramer's Avatar
JoeKramer
Walked out to the truck this morning and it will not start. No solenoid click. Swaped batteries with a known good one and still the same. Pulled out the remote start switch and hooked one side to the 'S' and the other to the battery and the solenoid clicked and the starter ran.
So it must be the wiring from the key to the solenoid or the key switch itself.
Is there anything I should check that is specific to these trucks for this issue?
I'm thinking of just putting in a starter button, wiring one side up to the ACC (maybe radio) and running the other wire to the 'S' on the solenoid.
I have a '76 F150 extended cab short bed with a 390 AT. I think it has dealer installed AC.
Old Apr 7, 2011 | 07:38 PM
barbsbuddy's Avatar
barbsbuddy
I would begin by checking the neutral safety switch which is located above the steering column under the dash. I think this is the only point of interruption between the ignition switch and the starter selinoid. The neutreal safety switch could be bad, have a loose connection, or be misaligned. Was the shift level in paerk or neutral? Try starting the truck while moving the shift lever up and down.
I would not bypass this switch because then the truck will start in any gear.
Old Apr 7, 2011 | 08:27 PM
JoeKramer's Avatar
JoeKramer
UG! it was the neutral switch.
Thanks man! I'm not thinking very well today.
Old Apr 8, 2011 | 03:07 AM
78 PEB's Avatar
78 PEB
Funny what you can figure out AFTER you cool down a bit and think things thru.............I HATE when I do that crap............LOL
cityjack
Feb 9, 2014 08:49 PM
brad7.3
Feb 5, 2013 08:59 PM
obx 79 shortbed
Sep 29, 2012 09:46 AM
99hosss
Jul 31, 2012 08:53 PM
smoky_diesel
Jul 6, 2009 11:50 PM
