to much coal
Old Apr 7, 2011 | 05:36 PM
BlueOvalBud's Avatar
BlueOvalBud
For me, the K&N was a huge improvement compared to the stock oil-bath air cleaner on the ol' 65.
It definetly makes a big difference in the go-pedal! With the X-Treme air top, I can actually hear the air sucking thru the filter riding in the cab. It's just as addicting as a turbo whistle
At the time, I didn't know squat about engines/cars/trucks...I just liked the HP increase sticker
With the knowledge I've gained now, I may end up putting a K&N in my stock IDI air cleaner housing and run dual ram air intakes from the grille, one on eachs ide of the radiator.
At some point here, I'll be doing the intake tubes with the stock filter anyways...but since the filter is dirty and may need to be replaced in a few months, I may upgrade to a K&N since this truck sees 95% of its time on pavement in a non-dusty environment.
For a vehicle that sees a lot of dust, I'd keep the disposable paper filter.
For a vehicle that sees a lot of time on road, I'd run a K&N and just it clean and oiled up.
Old Apr 7, 2011 | 05:43 PM
snaponprofile's Avatar
snaponprofile
Lemme know if you want my stock k&n filter, I put it on at 100k and did the turbo at like 105k so it's relatively new and collecting dust.
Old Apr 7, 2011 | 05:49 PM
BlueOvalBud
It fits right in the stock metal air cleaner housing right? Not one of those clamp-on cone types?
Old Apr 7, 2011 | 06:34 PM
Fordownsall's Avatar
Fordownsall
while you guys are on the topic of air filters sort of... how often would you recommend replacing the air filter?
also. that little fuel screw is the same concept for the 7.3 right?
Old Apr 7, 2011 | 06:49 PM
snaponprofile
Yeah, it fits right into the stock air cleaner
Amazon.com: K&N E-1460 Replacement Air Filter: Automotive
It depends on what filter you get, K&Ns are lifetime, all you do is clean it when it's dirty and reoil it. Just get a air filter recharge kit from your local auto parts store and follow directions. I'm pretty sure other filter should be replaced every 30K.(?)
Yes the torque screw is the same but it only came on 92.5-94.5 IDIs. However, when you need a new IP, you can replace it with a 92.5-94.5 pump.
Old Apr 7, 2011 | 06:52 PM
Fordownsall
well my truck is a 91 and i just went out and looked.. there is a little orange cap over something in the exact same location of the torque screw in that video.. is this something diferent?
Old Apr 7, 2011 | 06:58 PM
snaponprofile
Yes, I wouldn't touch that one, if you have a torque screw you will see two plastic caps at the back of your IP and the torque screw is the one closer to the top, I'm not sure what the other one does.
Old Apr 7, 2011 | 07:00 PM
Fordownsall
ok i didnt wanna mess with it anyways just wanted to check it out. and I have a banks air filter. i guess it came with the turbo? how often should these be changed/cleaned?
Old Apr 7, 2011 | 07:10 PM
snaponprofile
The banks filter is lifetime, and its a K&N filter that is just labelled Banks. Just get a K&N recharge kit from your local auto store, don't cheap out and get a store brand, its not compatible with the banks filter. Basically it has a spray that loosens the dirt, then you rinse it out and oil it.
Old Apr 7, 2011 | 07:13 PM
Fordownsall
okay thanks. and how much do these kits run?
Old Apr 7, 2011 | 07:16 PM
snaponprofile
Amazon.com: K&N 99-5000 Aerosol Recharger Filter Care Service Kit: Automotive
Old Apr 7, 2011 | 08:08 PM
vfelix702's Avatar
vfelix702
This is my cold air setup .... I got the idea from "Wreck" and I have had it installed since early january and have never had any issues... Its all 4in Duct work all avaliable at O-Riley or your local parts store. Except the 5 to 4 inch Hub on the Plentum
Old Apr 7, 2011 | 08:31 PM
  #28
snaponprofile
What I want to do is find a shop that bends 4inch pipe and have them bend me up a prefect fitting dual intake. I think it would work and look awesome. I would route one to the pass side battery and the other to the right side of the rad. and paint it black. I don't think it would look bad, but who bends 4 inch pipe?
Old Apr 7, 2011 | 08:39 PM
  #29
vfelix702's Avatar
vfelix702
You could try using 4" ABS 90's and 22's and some 45's or to get some bends and things try heating up the 4 in ABS with a Torch and make it soft and try and Bend...... I do things like that for 1in schedule 80 for sprinkler lines at times with no issue.... But 4in is a diff story I have tons of it at work and ill see if I can get it to bend tommorw mornin just for the hell of it just to say been there done that ... LoL
Old Apr 7, 2011 | 08:45 PM
  #30
snaponprofile
I can't get any ABS around here, its not to to code so nobody sells it, I would love to do it out of ABS if only I could get my hands on some!
