in dash wiring colors needed
I do have one radio working but when I turn on the headlights the radio dies (the display goes dark but does not lose the time)
I attempted to install a radio from a 94 ranger but the adapters wiring from that radio to mine do not correspond.
Any help would be greatly appreciated.
Here's the link:
https://www.ford-trucks.com/forums/a...ic/102380.html
Hopefully that will help.
I found the paper i printed out... here are the colors and what they do to the best of my knowledge:
green - memory feed
black - vehicle chassis ground
yellow/black - radio power feed
light blue/red - panel illumination
orange/black - radio display
black/light green - radio ground
orange/light green - left front speaker +
light blue/white - left front speaker -
pink/light green - left rear speaker +
tan/yellow - left rear speaker -
white/light green - right front speaker +
dark green/orange - right front speaker -
orange/red - right rear speaker +
black/white - right rear speaker -
Hope that helps you.
I'll give it a try, I had one from another ranger (94) but I think I might have fried that radio
now going to try after market radios and see what happens.
here goes something I hope
Wiring Diagrams
Look about half way down. There is a pic of the wires and plugs. If your wires are the same color - there is the list. If they are different colors, let me know and I can try to match the wires up for you.
That's the plugs. The black match exact, the gray differs slightly.
Left to right Yours
green
black
yellow/black
light blue/red
orange/black
black/light green
empty
empty
Left to right mine
Light green w/yellow stripe
empty
yellow/black
light blue/red
orange/black
black/light green
red
empty
empty
when I plug in the speakers plug (black adapter) heard "sound" like speakers being powered. I then plugged in the black, the tape deck attempts to kick in - but nothing.
This entire time there is no display at all. 15 amp fuse is good (replaced MANY times
)I was going to try a radio from an 89 mecury topaz figuring lincoln ford mecury - but if I can get the ranger one running (Had great sounds) I'd prefer that one.
Thanks again cobraxp
can get display (clock) hooking up as follows
the radio's memory (pink) to truck's green w/ yellow stripe,
radio's red to truck's black with yellow stripe,
and black to black
It says a purple wire for the left + speaker, I have no purple wires in my dash. Nor any blue wires. Granted the site does give the "disclaimer" that ford changes wire colors even on identical years and models.
I do greatly appreciate the help though.
Oh BTW the first link in your posting
http://://www.partsexpress.com/pe/ps...number=265-653 results in a 404 error
you just need to remove the extra :// from the post before the www
I'm gonna get this truck a radio yet without having to pay someone else to do it : P
http://www.partsexpress.com/pe/pshow...number=265-653
Tempe
Tempe -
Just wanted to say the link you posted is very informative and useful. I hope you don't mind, but I bookmarked it to show others when they are need of that information...
Tempe
I reinstall the cheepy radio (boy can you tell) (2x 25w) I at least now have tunes.
The main problem installing it was the acc/run power that should be coming from the engine, supposed red wire, mine is black with a green stripe has no power through it. This is with the engine off, on, or in acc. I went and bought a digital multimeter thinking my cheapo multi wasn't functioning properly - but same results.
Anywy the only way I could get this to install was to run the radio's power to the always hot line the radio memory wire was connected. I just have to remember to shut the radio off when I get out of the truck.
I'd love to be able to hook the original wiring up but I realized I don't even know what the original radio/wiring was (premium/non-premium sound)
anybody happen to know what came standard in a 92 ranger XLT regular cab truck? Or any idea how to find out what came installed in this truck?
Thanks for all the great help/advice/and links.
