`03 Ranger axles....
Old Mar 18, 2003 | 08:16 PM
alwaysfords's Avatar
alwaysfords
Question `03 Ranger axles....
Greetings everyone! Just got a new Ranger and want to know everything about it. Hope you can help or direct me to someone who can. First thing on my mind is the axles. What kind are they? (Dana 35 fr. Ford 7.5 rr.?) All I know about them is that they have 4.10 gears and the rear has a torsen diff. Also, when I switch to 2WD do the axles disengage from the wheels (i.e. do the driveline and axles quit turning)?
Thanks,
alwaysfords
`03 Ranger FX4 Level2
`79 F-250
`68 Bronco
Old Mar 19, 2003 | 02:10 AM
brianjwilson's Avatar
brianjwilson
Congrats on the new truck. Not sure if it's a Dana 35 or not, rear should be an 8.8. From what I understand, the 2001 and newer Rangers have a live axle setup. Instead of having hubs that disengage the front drivetrain, it is always turning with the front wheels. When you switch into 4x4, all it does is engage the transfer case, the rest is already done... (somebody else correct me if I'm wrong)
Brian J Wilson
Old Mar 19, 2003 | 02:41 AM
Rand's Avatar
Rand
the fx4 level 2 has a shortened version of the explorer 8.8 axle
which is about 35% stronger than the regular 28 spline 8.8 axle.
the front if im not mistaken is some sort of hybrid d35.
Rand
Old Mar 19, 2003 | 07:42 AM
WXboy's Avatar
WXboy
On mine, the front diff. is permanently connected to the driveline. When you switch into 4x4, the hubs are actuated by a vacuum system, and the transfer case engages like they always have. I thought all 1998-2003 Rangers were the same as far as this system goes, but I could be wrong.
Old Mar 19, 2003 | 01:27 PM
Rand's Avatar
Rand
nope the newer rangers 2001+(i think) have live axle.
Which means NO HUBs either. Just the switch at the transfer case.
Rand
Old Mar 19, 2003 | 01:45 PM
WXboy's Avatar
WXboy
So does that mean the front driveshaft on '01 models spins all the time then? Because it would seem that a system like that would cause a lot of vibration. Or do the new Rangers disconnect at the front diff. in 2-wheel drive?
Old Mar 19, 2003 | 01:56 PM
Rand's Avatar
Rand
Yes everything always turns.. when you shift it to 4wd. It engages the front at the tcase thats it.
Rand
Old Mar 19, 2003 | 02:22 PM
brianjwilson
Right,
Basicly, it's just like having your hubs engaged all the time. My question is, do the new trucks get worse mileage from this? I know many manufacturers do this live axle setup now. People always say that leaving your hubs locked (if you have manuals of course) makes your mileage worse. Does the live axle setup have different components than the auto-hub setup?
Brian J Wilson
Old Mar 19, 2003 | 02:34 PM
Rand's Avatar
Rand
Yes.. it has NO hubs
And yes probably 1mpg less or so.. i average 15mpg in the winter
and about 18 in the summer. with the 4.0 (2002)
alwaysfords41
Jun 12, 2013 08:47 AM
alwaysfords41
20
Jul 31, 2009 06:29 PM
alwaysfords41
Aug 4, 2008 08:08 AM
alwaysfords41
Apr 11, 2008 12:36 PM
alwaysfords
Apr 17, 2000 03:26 AM
