Trans code 'M' and gear ?
Old Mar 18, 2003 | 08:14 PM
rhetor's Avatar
rhetor
I have a trans code M on my door jamb. Does this mean mazda 5OD?
I have an open 3.55, which sucks in the mud. How hard would it be to swap out for a LS (junkyard) 3.55 4x4?
Thanks
Old Mar 18, 2003 | 08:49 PM
steve83's Avatar
steve83
Yes, M is the code for the Mazda M5OD. If you swap the whole axle, it's a bolt-on. If you just want to swap the diff carrier, you have to have the gears set up again, and you might as well rebuild the clutch packs.
Old Mar 19, 2003 | 05:30 AM
rhetor's Avatar
rhetor
thanks steve.
I'll probably want to take one apart and rebuild it, not out of neccessity, but for the experience. I'll have to check out prices and such... maybe a locker is what i want.
Can i simply put a locker in the rear? I couldn't see why not, other than I would be better off with the front wheels seeing as they get the traction in a pickup.
moosey78
21
Mar 19, 2014 05:45 PM
FLOATTUBR
35
Jul 28, 2011 01:36 PM
Mustangfreak
31
May 10, 2010 09:28 AM
svt2205
2009 - 2014 F150
Mar 23, 2010 01:22 PM
TonyG
Sep 5, 2002 06:35 PM
