CCV & MPG
Old Apr 6, 2011 | 01:10 PM
ztodd377's Avatar
ztodd377
CCV & MPG
Ok, so for the past couple of years I've been getting between 11 & 14 MPG mixed driving. This is based on hand calculations. Was thinking about putting my CCV back to stock formation to see if my MPG goes up any. Has anyone done this experiment it? If so and there was no improvement then I'll skip it, but if not then I'll try it and post results. I know it's more of a mess in the intake and some oil through the IC but if MPGs go up I'm all for it.
Old Apr 6, 2011 | 01:28 PM
cj45lc's Avatar
cj45lc
I don't believe it will have an effect one way or the other
Old Apr 6, 2011 | 01:32 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I just put my CCV back to stock. I got tired of the smoke and smell. I have not noticed any change in MPG's but I havent really really been checking either. Let us know what you find out.
Old Apr 6, 2011 | 02:02 PM
JOHN2001's Avatar
JOHN2001
I just put my CCV mod on a couple of weeks ago and my MPG hasnt changed at all
Old Apr 6, 2011 | 04:09 PM
ztodd377's Avatar
ztodd377
I'm gonna run a tank as is, then another with it back to stock. I'll keep you posted in 2 or 3 weeks when I've got the results.
Old Jul 6, 2011 | 10:47 AM
ztodd377's Avatar
ztodd377
So I've run a couple of tanks just to be sure that my results are good. I ended up getting about .25 to .5 MPG more with the CCV in the stock (OE) position. These are just my results and results for others may differ. I've even been driving faster than normal (70-80MPH) and being more aggressive with the throttle to make sure I wasn't babying it subconsciously to produce the desired results.
Old Jul 6, 2011 | 01:00 PM
HH60FE's Avatar
HH60FE
Interesting. I wouldnt of thought that it would make a difference.
Old Jul 6, 2011 | 01:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I also, have heard that the stock CCV setup produces about .5 mpg better.
Old Jul 6, 2011 | 02:24 PM
MIKEYLIKESIT1's Avatar
MIKEYLIKESIT1
i've had my truck for 6 years and just did the ccv mod two monthe ago. no change in mpg so far. the engine bay stays somewhat cleaner now tho.
