Emergency Flasher Indicator Wiring
Old Apr 6, 2011 | 12:39 PM
sammycooks's Avatar
sammycooks
Hey all...
I want to install an indicator (an original that I pulled from the yard) into the dash. As far as I can tell, my truck didn't come with one. Can someone tell me where to wire it? It is a 2 wire, one being a ground. I have a bit of a rat's nest behind the dash (working on sorting it out), and some of the wires have paint hiding the color... Currently, pulling the EF switch intermittently lights the turn signal indicators (which are LED's thanks to the PO).
Thanks
Old Apr 6, 2011 | 02:04 PM
garbz2's Avatar
garbz2
The stock emergency flasher, switch and light are a seperate plug and play harness.
PM numberdummy and ask for the correct part number and check for NOS harnesses. There out there as they were an optional accesory.
Or go back to the yard and get the harness it all unplugs in line with the TS switch wiring.
Garbz
Old Apr 6, 2011 | 09:02 PM
sammycooks's Avatar
sammycooks
Thanks, Garbz... I'll probably check the yard... I do already have the switch (which was already installed) and the light/bezel... so do I really need an entire harness?
Old Apr 6, 2011 | 11:23 PM
Broomfieldbum's Avatar
Broomfieldbum
Since the subject is out there, how would one wire this switch, and light if you have a aftermarket harness?
Old Apr 7, 2011 | 08:39 AM
garbz2's Avatar
garbz2
Either you use the ford harness or cut and splice it in line. I prefer the ford harness as it has the correct ends for the bullet early connectors or the square plastic for later.
You all ready have hazards on your aftermarket harness. Look to the directions in the kit. They will blink your current TS lamps in the bezel.
Garbz
Old Apr 19, 2011 | 07:44 PM
66blue's Avatar
66blue
66 turn signal switch- need one
How's everybody, Hey I need a 66 f-250 turn signal switch, new or used. any one able to help? Gayle 864-414-0757
Old Apr 19, 2011 | 09:04 PM
Broomfieldbum
You can get one from Ford. I bought mine at the local Ford Dealership. You can get them from Dennis Carpenter, or LMC also, but I think they are more expensive from them.
fp_5
2004 - 2008 F150
Mar 2, 2015 04:42 PM
Stormcloud
Aug 12, 2011 12:16 PM
skeith5
Mar 29, 2011 06:31 AM
The Frenchtown Flyer
1947 and Older Ford Trucks
Aug 12, 2007 10:21 PM
volleyball33
Aug 17, 2002 12:17 PM
