Hey Chet,
You better give jv some serious props, (Click his Heart), or I'm comin' over there and remove that bulb fer ya!
Glad to hear ya got it figgered out.
Hi, this not so much along the same lines,but years ago i read somewhere on
the older cars especially fords you would them going the road with yellow head lights and that problem was supposed to be a bad ground,also unless
it has changed i believe fords regulators are grounded on the fender where
they are mounted. just food for thought.
Hey Chet,
thanks for the tip!! i dont think i could click that heart enough for what i owe him!
mine did the same thing (it is however a 91 with a 300) it turned out to be the plug behind the gauges that runs the battery light was unplugged, plugged it in (after spending almost 300 bucks on new parts) and it worked fine
