MISSING ON AN INJECTOR??????
Old Apr 6, 2011 | 11:17 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
okay, with that one i can definitely hear a difference... what would be the best way to figure it out? just start taking stuff apart? take it to a local shop??? any suggestions???
Old Apr 6, 2011 | 11:27 PM
wheelie31's Avatar
wheelie31
Just keep doing research on here and hope more people chime in. If jim from rosewood says its injectors id tend to belive him. Id try to stay away from taking it to a shop unless you have deep pockets.
Old Apr 7, 2011 | 12:40 AM
BuckHammer's Avatar
BuckHammer
Yeah, wheelie's video does a good job of showing what an idling Powerstroke should sound like.
Old Apr 7, 2011 | 06:09 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I tried to post yestarday but DSL dropped.
What I would do is remove the valve covers, start the truck and unplug the injectors one at a time and see if you can find the one injector (or more? do them all) that does NOT make the engine stumble when you unplug it. This is the one NOT firing.
Then, you can swap the valve cover gasket and under cover harness one at a time to the other side, re-start and see if that intial cylinder still does not work or if the problem moved with the vc gasket OR under cover harness.
This will help narrow down if it is an injector or the gasket/wiring.
If you see it is the initial injector still not firing after swapping parts, I would swap that injector quickly with the one next to it to make sure it's not the IDM or other wiring issue. If the injector is the culprit it won't fire in the new hole either. If it's something else then that initial cylinder still won't fire.
Make sense?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 7, 2011 | 09:56 AM
f350rebel7788
Ok, that makes sense! Well, I guess there's nothing to do but check it out! With my luck, I'll be sending you some injectors for an upgrade jim!
Old Apr 7, 2011 | 10:07 AM
Robbgt's Avatar
Robbgt
Thanks for posting the test Jim, Rep sent. I need to do this on my truck as well
Old Apr 7, 2011 | 07:05 PM
kupiec20's Avatar
kupiec20
YouTube - FORD DIESEL OBS
symptoms are when i try to start it when the engine is not warm thats what it sounds like (also if i shut it down when its not warm it sounds not good) if i start at op temp all is well. any ideas?
Old Apr 7, 2011 | 07:57 PM
Krisx125's Avatar
Krisx125
Ill start mine with a few dead glow plugs...and a Semi-working Glow plug relay..Oh and my auto PCM in my manual truck...haha talk about odd sounding..
Old Apr 7, 2011 | 09:08 PM
jtexfisher's Avatar
jtexfisher
Yup....Wheelie's sounds a bit different than what I'm used to. Two things in particular. First, I don't hear near as much of a LumpLumpLumpLumpLump in his. Second when he lets off the throttle it goes back to a solid idle immediately with no stumbling around before it "finds" it's beat again.
Wheelie, I assume when you went from high speed to idle you did a quick drop off the go pedal????
DZL JIM, many many thanks for the good diagnostics!
Old Apr 7, 2011 | 11:03 PM
wheelie31's Avatar
wheelie31
Ya mine dont have a loping sound like some do, And yes mine dont stumble at all when i let go of the pedal from reving, Which i love, before it use to stumble around till it caught itself but then i swaped the injectors and had them rebuilt by jim and that took care of that problem
Old Apr 8, 2011 | 06:05 AM
427 fordman's Avatar
427 fordman
I guess I can't hear anything too bad here, what are you asking for sure?
Old Apr 8, 2011 | 08:29 AM
Krisx125's Avatar
Krisx125
I think he was asking about the stumble apon start up.
Old Apr 8, 2011 | 09:16 AM
  #28
kupiec20's Avatar
kupiec20
yes. also it stumbles when shut it off when cold.
Old Apr 8, 2011 | 09:34 AM
  #29
427 fordman
can't help you there. I used to notice that on mine but after I did all my upgrades and repairs I don't remember hearing it. Sorry
Old Apr 27, 2011 | 06:39 PM
  #30
84-250's Avatar
84-250
Is an idling PSD motionless in the engine bay or does it have a rock to it?
What would cause an injector to discharge more or less oil then the rest?
Dont think this a
