auto to 4spd swap
auto to 4spd swap
i have a 77 F250. have a divorced C6 in it now and im swappin in divorced NP435. i believe i have everything i need. steering column pedal assembly linkages brackets, crossmember driveshaft ect.... i know of a spring and the rubber boot for shifter yet. otherwise im set..... im not sure how many of you have done this swap but im assuming theres plenty. i want to do this right and look good. any little tips or tricks you guys have for gettin the job done right?
sounds like you have every thing. It takes a little time but its not bad Ive done a couple. It works best to have the cabs side by side and swap over as you go. I dont know if your parts are already out or not . If your parts are already out and in a pile have a 4 speed around that you can look at if you need to. It easier than having a hand full of parts and have to figure out where and how they fit
TA455HO
03-18-2013 10:10 AM
Craigwell
02-02-2006 01:08 AM
