Heater Core/Coolant System
Old Apr 5, 2011 | 01:27 PM
pineappleking's Avatar
pineappleking
Angry Heater Core/Coolant System
Hello,
I am at wits end with trying to figure out what is wrong with my 1996 Ford F-150. I was driving about a week ago and some guy at a stop light told me I was leaking coolant pretty bad underneath my passenger side. I went home and found out where it was leaking from. There is a small, black, hard plastic line coming from my cab and going to the engine compartment (about 3/8" to half inch in diameter). The length from the cab to where it stops is about 2 inches. The coolant was gushing out of there and I thought I have a huge problem on my hands. I did some research and still have come up with nothing. My heat works fine in the cab so I am assuming it is a return line from the heater core going to the radiator. The problem is is that there is no broken or disconnected hoses anywhere underneath the hood, which makes me wonder how (if) there is a hose connecting the two ends together, why would it come off both ends at the same time? If anyone out there knows what this is or can help me out in any way I would greatly appreciate it. I have pictures of exactly where it is leaking that I can email to anyone. Thanks again in advance.
Rob
Old Apr 5, 2011 | 01:50 PM
rikard's Avatar
rikard
It sounds like your heater core is leaking. The line under the truck is the drain for the AC/heater box. Fortunately the heater core replacement is a very easy job on these trucks. Last one only took me an hour.
regards
rikard
Old Apr 6, 2011 | 10:53 AM
pineappleking
rikard - is there another thread or another post that tells how to do this? i know it is behind the glove box but that is about it. thanks in advance
holymolie
22
Mar 29, 2011 12:54 AM
MotorMouthChica
15
Oct 3, 2010 06:07 PM
Justin's Green Truck
1997 - 2003 F150
Mar 28, 2010 09:12 PM
slychicken37
Nov 19, 2006 08:01 PM
mhjohnson48
Jan 6, 2003 06:49 PM
