I have a '91 E350 with hazard light probs. When I turn them on, only the right rear light blinks. I replaced the hazard flasher relay, but that didn't do anything. My signal lights work fine.
I believe that it could be your multfunction switch. You may want to try operating it several times as this will make the contacts wipe against each other and clean themselves. If that doesn't work you may try some contact cleaner.
On a 77 Ford pickup that I had the hazard switch was on the right side of the column and the turn signal switch was on the left side of the column but they were just one part. The part was light a donut that went around the steering column. I suspect that on your truck the hazard switch and turn signal switch is one part also.l Operating the switch several times solved my problem.
