Magic Air heater restoration progress
My guess is they are not in your price range!
Wow, the format of this thread is messed up! must be the smell of fresh paint! Or maybe just the pictures???
They had ductwork that ran under the fender and brought fresh air in the cab. You can shut the heat off buy a pull of a cable instead of getting out and shutting the valve off. You could get just fresh air if you wanted. It was supposed to pressurize the cab somewhat to reduce wind noise. They looked better and fancier. you had the option to shut the defroster on an off.
The Magic Air fresh air heater was a $62.40 option in '52 .Seen this # on a build sheet on a '52 in the truck corral at the Nat's in '06 and will never forget it . It was either pay the price or freeze you a$$ . It also gave you the option of defrost or defog as opposed the standard recirculating heater that only gave you heat and defog . One could open the fresh air door in summer and obtain cool clean outside air for the cab .The air enter in over the screen coverd duct above the right front fender and traveled thru a 4" round tube to the RF kick panel .
EXPI2006
1997-2006 Expedition & Navigator
05-21-2012 09:31 PM
lamenytro
29
11-11-2010 12:06 AM
1990ididually
07-07-2010 05:42 PM
