E-brake mystery
The ones I bought at Carquest had 2 different part numbers, the only difference was the brake line fittings were on different sides, pointing in different directions. I'll see what I've got tomorrow...until then, I'll dig for pics.
im beginning to think this e-brake setup is just junk from the factory.
i figured out my problem on the drivers side.i put a screw driver on top of the wheel cylinder and pried down.apparently the backing plate was bent.this explained why that part was hitting it.
so now both levers fully work and push the shoes outward.
however it just doesn't seem to be enough to work worth a darn.
the cables fully pull them back and the only way i can get the brake to pretend to hold sub par,is to over tighten the shoes so the wheels can hardly turn to start with,which of course sucks.
it MAY get me by for an inspection,but it certainly wont be worth anything at all once i come home and loosen them up a bit so my brakes don't catch on fire going down the road lol.
man what a hassle trying to fix a poor setup that i doubt worked much better from the factory.
even with the shoes over tightened and dragging right now,it would be worthless in the event of a hydraulic brake failure.
im so frustrated and sick of pulling tires.
any suggestions as to what to rig up to make an actual working emergency brake,that would pass inspections with flying colors and actually stop the truck if i lost my brakes? i pretty much lost all faith in this stock trash setup.
a pickup dually axle w/ disc brake conversion (with working e-brake calipers) is likely what i need here.dang it though,all that will run upward of another grand.
On a good note, it's nice to hear you found a bent backing plate.
As for helping in an emergency, I think our trucks are a bit too heavy. I "kinda" had working e-brakes with all brand new parts on my first truck. But, when a hydraulic brake line did blow out, the E-brake pedal went straight to the floor when i hit that. Friggin cable snapped
That was an interesting ride thru the 4-way intersection....
In the thread Sterling Disc Brakes, Tecgod and I were discussing driveline parking brakes as a way to get a parking brake without using calipers with parking brake cable provisions. The setup I have on my '65 is mounted on the output shaft on my NP435 4 speed. And that thing WORKS!!!
To pass yearly inspection here in MA, the parking brake must hold the vehicle from moving in gear. With 4.10's in the rear end, and putting the thing in granny gear (6.69:1
). That brake stalls my 352 FE!! I've never even opened it up either. It's operated by the hand lever to the far right in this picture.
My next step for this 85 is to make a driveline brake from an F-Superduty ZF5 fit the back of my T19. No idea if it'll work, but it's a shot!
Something along those lines might be in your future?
http://www.4x4wire.com/toyota/reviews/parking_brake/
http://highangledriveline.com/e_brake.html
Not gonna be a bolt-in, but maybe it could be modified?
Last edited by BlueOvalBud; Apr 10, 2011 at 12:17 PM. Reason: Added links and picture
That would get you upgraded to a Dana 60 dually front at the same time...in order to match the rear.
Unfortunately, that means all the money you spent on the dually adapters and dually wheels would be lost. Well not all of it, some could be re-cooperated after selling them.
Extreme suggestion for an e-brake though...kinda just thinking out loud...
*edit*
here is the link http://powerstrokenation.com/forums/...ad.php?t=78440
I know this through trial and error.I spent hours,after having everything replaced.I mean everything was wore and needed to be replaced anyway,the shoes,drums,all the e-brake cables,the shoe hardware.After all this though,I noticed the e-brake still wouldn't set with everything being brand new.These bent arms really fooled me for a few hours.That 3lb hammer put their proper curve back in them so when the pedal was pressed,the cables properly pulled to spread the shoes out against the drums and I had very nice emergency/parking braking.
Again though,this is after you follow everyone else advice about properly setting up the shoes and their hardware and only frig with this if needed.They got you covered so well with that part,I have nothing to add.......Well,since you have a nice pic of it,actually.If you happen to buy new hardware (yours all look fine.This is more for future searchers) this part,be mindful that it may need to be bent and tweaked (inward so that rides the wheel).Don't count on China parts being all set to go.
I know it's an old thread now, but that must suck to search and find this and not see the resolve. So in case anyone else can't figure it out, get that 3lb out and spread those bars back open!
It must have taken me like another month of head scratching or something and by that time, I must have forgotten to reply back here. I know I fixed this not all that much longer from when I started in on it. Just long enough to forget to post back I guess. It had me fooled for bit but after going through it all, I knew these bars must had bent. So if you stepped on your e-brake too hard or a previous owner did......Suspect the bars got bent too.
Oh, I noticed I was onto it in post 1, now that I look back, but I realized there was nothing else there could be. With a helper stepping on the e-brake, and seeing the cable move all it could, there was nothing else to do but smack some more curve out that bar too. It's the only thing left when all else is new, to not give you enough throw. That's all there is to it. So smack some more curve out of until it spreads the shoes apart against the drum. What's tough is, you don't have a new one to see what's supposed to look like, so it's just smack, and try, smack and try until enough bend it out of it, to where it spreads the shoes. There's really nothing else it can be, once you know everything else is in top shape.
I would then latter ditch this axle w/ dually adapters and bolt in a true DRW pickup axle. Never had any issues with this one that I remember.......but it's the same system. Could happen just as easily. This is the fix and I remember it wasn't easy to get some bend back out of those. I really had to wail on 'em! I might have even resorted to grabbing the maul to pound the bend out of that stubborn side, wouldn't surprise me. You have to take them right off the truck of course and set them on something solid and whack them harder than you'd think you'd ever have too but they will straighten back open a bit, believe it or not.
