glowing manifold
Old Apr 4, 2011 | 07:30 PM
ctruf1504x4's Avatar
ctruf1504x4
Question glowing manifold
what would cause my exhaust manifolds to glow red?
Old Apr 4, 2011 | 07:42 PM
Hotshot869's Avatar
Hotshot869
Heat my friend, Heat. High RPM's. Wheelin through a field, things like that.
Old Apr 4, 2011 | 07:51 PM
ctruf1504x4
glowing manifold
Sorry for that the rest of the info did not post so here it is. The truck has been acting up no power. I cut out the cats and no change, I was driving down the road after i changed out the egr vac selinoid to see if that was the prob bc the old one was cloged up. thats when i noticed the glowing it is the first time i tested it at night and never noticed it befor.
Old Apr 4, 2011 | 07:57 PM
raytasch's Avatar
raytasch
Believe Nothing
Running lean is my guess. Long time full power will cause it also.
Old Apr 4, 2011 | 08:33 PM
skyfox10's Avatar
skyfox10
X2 on the lean mixture. I'm not 100% but I think your timing being off can cause this as well.
Old Apr 5, 2011 | 04:52 AM
EPNCSU2006's Avatar
EPNCSU2006
It could also be caused by an overly rich mixture or late (retarded) ignition timing.
Old Apr 5, 2011 | 08:58 AM
rla2005's Avatar
rla2005
My last '93 Lightning lit up the manifolds and all 4 converters a few times before I finally tracked down the problem...... bad PIP in the distributor. When it acted up the truck lost power, like no fuel. Turns out it was effed up spark timing caused by the PIP.
Strangely enough I never got an error code when the truck was running this bad.
Old Apr 5, 2011 | 09:02 AM
skyfox10's Avatar
skyfox10
Originally Posted by EPNCSU2006
It could also be caused by an overly rich mixture...
I thought a rich mixture would only cause excess heat at the converter, but not before. Am I mistaken here?
Old Apr 5, 2011 | 09:17 AM
White Max's Avatar
White Max
Incorrect plug wire routing can cause that as well.
EDIT: By incorrect routing, I mean placing the wrong wire on the plug (I.E. #1 wire on #2 cylinder's plug).
Old Apr 5, 2011 | 10:44 AM
Homeslice's Avatar
Homeslice
I had the problem with my 93 mustang when I rebuilt the motor. I had a defective fuel pressure regulator and my fuel pressure was over 50lbs so it was running way rich. Had my headers glowing red within a few minutes.
Old Apr 5, 2011 | 03:28 PM
ctruf1504x4
glowing manifold
I drove the truck today and notice that I am using a lot of fuel.
Old Apr 5, 2011 | 05:15 PM
ctruf1504x4
glowing manifold
found the problem, some how the dis hold down got loose and the dis moved retarding the timing moved back to where i think it should be but no timing marks for me to make sure so how do i know if its right.
Old Apr 5, 2011 | 05:17 PM
skyfox10's Avatar
skyfox10
your harmonic balancer doesn't have timing marks?
Old Apr 5, 2011 | 05:22 PM
ctruf1504x4
glowing manifold
no and my book says to look on the sticker under the hood and the sticker says that the timing cant be adjusted.
Old Apr 5, 2011 | 05:34 PM
White 97 xlt's Avatar
White 97 xlt
BULL, you need another book!!!!! Pull the spout connector, slap timing light on #1, move dist to where it shows 10 degrees before TDC , tighten dist. Drive off smiling..
Sticker is WRONG!!!!!!!!!!!!
