M5OD noise
Have an M5OD in an f150. When I bought the truck I had the fluids changed that day. They told me they could not drain the trans. fluid but they replaced it, (because there was none to drain out). That night I made a nice pool of trans fluid in the drive. I went back and asked why they didn't use 90w or something.. ok who knew, I guess they were right but I then replaced the output shaft seal and the 3 plugs at the top rear. After DAYS of letting it set up and dry, I drove it without issue to this very day.
It is however whinny. Is this normal or did the heat that melted the speedometer drive gear (prior to the oil change thing) also change the temper or surface or shape of the gears?
Guess I'm just asking if M5OD's typically do make a little "gear drive" type noise.
Bearings are compromised, possibly gears.
Other wear items are the shift forks.
Plan on putting bearings in it asap, maybe you can save it.
I'd also have the oil changed again to see if you are getting metal in the oil.
Surprisingly, I have an update, which is odd since I have driven it for such a long time like this with no problem and yesterday while nit-picking things that need to be better on my truck I came up with that concearn... well, today on the way to work, I noticed the truck sounds like the entire exhaust is on the truck with loose bolts. When I put it in gear and drive the rattles all go away.
I am feeling the bearings are going.
So now I am wondering if I can likely replace the bearing (via typical ebay rebuild kit) and keep truckin' or will I have to replace gears and crap.
I know it's not likely anyone will know without tearing into it. It most likely would be easier cheaper quicker to just put a junkyard transmission back on, but i hate that idea since it could be my transmission a month or two ago ya know?
