Slightly out of focus or a soft focus lens was used. But, probably not what you are looking for.
That's the not very good photographer part. It was taken with a 300mm lens, through a dirty window, then cropped and shrunk so it could be reasonably uploaded and viewed on a moderately sized monitor.
I'm not exactly sure what you mean by an installed feeder, however.
While the entire feeder is clearly not shown, the feeder is complete as purchased from the store. The only change I made to it was to take the plastic perch dowels out and replace them with wooden ones.
Below the lower birds, out of the frame, is the third set of perches. At the lower right, you just barely see the head of another bird.
