questions( main stud, rear sump, windage tray)
Old 04-04-2011, 03:35 PM
mustang_gt_350's Avatar
mustang_gt_350
mustang_gt_350 is offline
Ok, I'm tearing down the old 360 so it can make its way to the machine shop. for a larger crank
I have a few questions.
1. I want to use the stock rear sump pan, but i want to run main studs. I already have the arp stud kit, but what do I do about the pickup tube mount? Does ARP make a stud with the stud on it for the pickup mount? Or am i SOL?
2. Is there a rear sump windage tray that will allow you to run the stock pan? Or will the studs i have interfere with it? Im not real concerned about a windage tray as for the purpose of this engine i don't think i will benefit all that much from one, not enough to make it worth buying another set of studs to accomodate the tray.
Any info would be nice. I hate to use the stock bolt with the stud on it and use ARP studs in all of the other holes.
Old 04-04-2011, 05:02 PM
tater_51's Avatar
tater_51
tater_51 is offline
I just finished a rebuild using the ARP stud kit. I just enlarged the hole on the pickup tube so it would fit the ARP stud. I then torqued the main with the ARP nut/washer, then used a SS jamb nut to hold the pickup tube. Checked clearance with the pan and everything worked out well.
Old 04-04-2011, 05:13 PM
mustang_gt_350
Awesome Idea. Thanks. Never thought of doing that.
derbydad276
11-20-2016 10:30 AM
hasteranger
12-21-2012 01:07 AM
billybob_81067
10-07-2006 10:16 PM
bdad57
01-28-2006 04:31 PM
77300i6
02-16-2005 02:52 PM
Quick Reply: questions( main stud, rear sump, windage tray)
