Modular V10 (6.8l)
repaired my eBay header
Old Apr 4, 2011 | 01:13 PM
grec-o-face's Avatar
grec-o-face
First off - sorry for not providing pics - I was in "get it done" mode. It's very unlike me.
After several months of dealing with a cracked drivers side eBay header - I finally pulled it and welded the cracks. I MIG'd the header using non-stainless wire. I had the stainless wire, but I'm so fed up with the horrible leak - I didn't even care. Ya, I know it'll rust - still don't care.
Under the header wrap I found two tubes cracked along the collector. The shortest tube and his neighbor were the culprits. Both tubes had cracks running at least 50% around.
I think the header wrap is to blame here. Below it I discovered black, almost burnt looking pipes. The wrap was extremely brittle and disintegrated into a powder as I cut it away. I'm pretty sure the wrap kept the heat trapped in the headers, not allowing it to disipate quick enough. I know many people run these headers without issues - in even harsher conditions than I. So, I'm calling out the wrap.
I replaced the header and sealed it to the head using RTV Ultra Copper. No gasket. I've had good results with this method in the past. I allowed the RTV a full 24+ hours to cure before driving the truck. Today is day one - so far so good. And I can say - driving a truck that doesn't "TICKK THICKK TICKK THICKK THICKK THICKK THICKK...." is quite a treat.
Needless to say, I didn't re-wrap the header. I guess I'll see how long it'll last.
Old Apr 4, 2011 | 06:44 PM
dkf's Avatar
dkf
Get some VHT ceramic header paint and paint the headers. It will help the heat transfer (into surrounding areas) a little and help keep the steel MIG wire from rusting.
Old Apr 4, 2011 | 07:03 PM
sandman3510's Avatar
sandman3510
FWIW, I welded in my Ebay Y-Pipe with standard MIG wire, and it's held up well for over a year now, WITH some high heat paint on it.
Old Apr 5, 2011 | 08:01 AM
grec-o-face
Damn, I really wish I thought of painting the header while it was out.
Or posted about the job before I did it - then I could've acted on your suggestions. I'll just have to get in there and make it happen.
Thanks for the good ideas!
EDIT:
Day two - so far so good! I really want to put some weight behind it and go run down the highway to build some heat. But that'll have to wait for another day.
Old Apr 5, 2011 | 08:07 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Interesting to hear about your issues. My headers are still pretty decent, even shiny for the most part. I haven't towed heavy with it whatsoever although I have had it idling/running-slow in 90+ degree heat for 4-5 hours at a time.
I was on the fence about wrapping my headers when I put them in. In a way, I'm glad I didn't. The only thing I wish I did was put dynamat on the firewall
Old Apr 5, 2011 | 08:25 AM
grec-o-face
I really think the wrap is what did mine in. I think the tubes are a bit thin and just can't handle the heat when wrapped. Of course, the wrap proved to be EXTREMELY effective as a sound barrier. Now that I've removed the wrap I can hear the "header flutter" quite clearly. That tinny sound that's cool in a big block Chevelle - but not so much in my Lariat SD.
The winter months made my "not that bad" leak - very bad. Plowing 3 feet of wet snow all day, all night without shutting the truck off for 30 hours is enough to drive some temps up in those headers.
Old May 29, 2011 | 02:25 PM
tnelsmn's Avatar
tnelsmn
My ebay headers turned black and crusty in about a week.
