I'm I missing something (with Pics)
Old Apr 3, 2011 | 07:40 PM
Pro DIY's Avatar
Pro DIY
I was replacing my fuel filter this afternoon on my wifes '06 Expy. This was the first time I was under it since getting it late last summer. So when I was done with the filter I was looking around underneath just to get the lay of the land. I saw something that didn't look right. It look like I am missing a plug or something. I took a couple of pics of it and put red circles around the area that I am questioning. I looked up the whole and could see something that looks like a gear. So please let me know if I am missing something and what the gear thing is. Thanks for your time.
Old Apr 3, 2011 | 07:46 PM
DPorter's Avatar
DPorter
flywheel. probably should have a rubber plug there.
Old Apr 3, 2011 | 08:17 PM
big poppa's Avatar
big poppa
Looks like the inspection hole for the flywheel teeth like Dporter said, awfull rusty in there.
Old Apr 4, 2011 | 12:15 PM
E. H. Hall's Avatar
E. H. Hall
on my 2002 nav there is a rubber plug there that allows you to turn the torque converter to its drain plug allowing you drain the torque converter on fluid changes
Old Apr 4, 2011 | 04:24 PM
pdqford's Avatar
pdqford
Verrry inneresting!!! My 2002 Navigator has the rubber plug but doesn't have a drain plug in the converter.
Old Apr 4, 2011 | 10:05 PM
hodges710's Avatar
hodges710
Its not a deal if this piece is missing, all of these transmissions have them even if yours does not have the actual drain plug in the TC.
Old Apr 5, 2011 | 02:30 AM
Moto Mel's Avatar
Moto Mel
It is supposed to have a plastic plug there. All of the 4R70 trans have it and I believe the 4R100s do too. I suggest picking up a plug from the dealer or almost any transmission shop should have a few laying around from some old cores. It is also to keep dirt and debris out of that area. There should also be a plug in the hole of the block opposite of the starter for the same reason
Old Apr 5, 2011 | 06:20 AM
cbradford's Avatar
cbradford
Not a big deal, as stated above just pick up a plug. A quick trip to a salvage yard, dealer, trans shop and you'll be set but don't lose any sleep over it!
Old Apr 5, 2011 | 07:24 AM
Moto Mel's Avatar
Moto Mel
I would suggest making it a small deal though, as road salt and other debris like sand and dirt will get in there and attack the seals. Once the seals start leaking it becomes a BIG deal.
Old Apr 5, 2011 | 07:30 AM
cbradford's Avatar
cbradford
Good point!!!!!!!!!
Old Apr 6, 2011 | 09:16 PM
Pro DIY's Avatar
Pro DIY
Will probably stop by the dealership on the way home from work tomorrow to pick up the plug. When I get the plug should it do anything before replacing the plug. Should I spray some lube or oil up there? Let me know what i should do before sealing it up.
Old Apr 6, 2011 | 09:37 PM
Moto Mel's Avatar
Moto Mel
Just push it into the hole until it clicks/seats and all is good.
npd23
18
Mar 24, 2021 08:18 PM
JRC99408
51
Mar 15, 2021 08:25 PM
Nally427
21
Nov 2, 2020 04:43 PM
ReBilld
51
Jul 14, 2012 06:39 PM
77 Supercab
Aug 10, 2011 08:46 PM
