rough idle when WARM
Old Apr 5, 2011 | 04:00 PM
whenry912's Avatar
whenry912
Originally Posted by 91dirtydiesel
Good idea on the gun cleaning kit!
Nope, can't take credit for that...just one of the millions of great tips I have picked up reading these forums!
Old Apr 5, 2011 | 07:46 PM
BlueOvalBud's Avatar
BlueOvalBud
I wouldn't think new injectors would be at fault...
I would be more willing to bet the Uhaul IP has issues. NOT due to a poor rebuild, more due to shelf time... I didn't hop on the sale, because I prefer to deal with my local shop...they take care of me very well.
I'd bet that running some cleaner thru the fuel system will help clear out any kind of build up that may be inside the IP.
X2 on cleaning the threads on the injectors!
I used a dental pick set, the shop vac, and I threaded a gasoline-soaked rag in the each hole many times before installing. I ran out of brake parts cleaner, I started with that on a rag...then turned to the gas.
Old May 19, 2011 | 10:38 PM
91dirtydiesel's Avatar
91dirtydiesel
Finally I figured out my problem!!! I reaplaced my K&N air filter with a regular 10$ filter and idles smooth as can be! And noticeably less smoke when driving!! ...K&N I am not impressed
Old May 19, 2011 | 10:59 PM
84-6.9L's Avatar
84-6.9L
Maybe your k&n just needed to be cleaned
Old May 19, 2011 | 11:08 PM
polarismuddman's Avatar
polarismuddman
I know you've gotten the problem fixed but Pensacola injector quality seems to be hit and miss...quite a few guys have ordered from them and gotten rusty, carboned injectors in the packaging along with cleary remanned ones.
Old May 22, 2011 | 09:58 PM
85grey's Avatar
85grey
I had a very rough idle when warm. It was also shortly after doing all new injectors and a pump withthe install kit. I had one of the return lines split out so the culprit was air intrusion, even though the hose was only a couple months old
'88f150
Aug 4, 2017 01:34 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 16, 2017 05:04 PM
roostonu
Jun 15, 2016 04:30 PM
kedynskrow
16
Nov 11, 2014 12:23 AM
mb5518
Sep 17, 2014 07:12 AM
