F350 Drivetrain Problems
Old Apr 3, 2011 | 06:36 PM
ventureout350's Avatar
ventureout350
Exclamation F350 Drivetrain Problems
I have a 2000, F350 Super Duty, 4wd, 7.3, Automatic Trans. I was pulling a trailer the other day and upon accelerating there was a "thunk" sound and I immediately lost all power to my wheels. It was like it was in neutral. I checked all of the gears and did a visual under the truck. I need to repair the issue myself and need some suggestions on where to start and any other input that may be useful. A friend thought it may be in the transfer case. Thanks
Old Apr 3, 2011 | 08:45 PM
justblowin'smoke's Avatar
justblowin'smoke
i'd check if maybe the transfer case jumped out of gear i had a gmc do that ounce
i'd pull the drive shaft off of the transfer case and see if the out put shaft is spinning
other wise it may be torque converter or over internal tranny issues
Old Apr 3, 2011 | 09:16 PM
ventureout350
Thanks, I'll check that out.
Old Apr 3, 2011 | 10:58 PM
clintbonnie's Avatar
clintbonnie
There is another similar thread here on the forum that was started afew days ago.. You might want to watch it and find out the cause of his problem .. See:
https://www.ford-trucks.com/forums/1...y-trouble.html
redneckfordman1
Mar 15, 2013 07:09 AM
f350fixaliter
Sep 10, 2010 12:28 AM
royzell
Jul 20, 2009 09:38 PM
thehickfarmer
Mar 13, 2008 10:17 PM
