1978 - 1996 Big Bronco
HELP
Old Apr 2, 2011 | 11:34 PM
JERSEY MUD's Avatar
JERSEY MUD
Exclamation HELP
i put a set of 3" blocks in the rear of my 96 ford bronco, and im getting a horrible vibration in the rear. the blocks were off-set a 1/32". were did i go wrong. i have a bad feeling its my drive-shaft. the front has a leveling kit.
im sitting on 31 10.50 15 s. i really need help on this one guys.
Old Apr 2, 2011 | 11:36 PM
JERSEY MUD's Avatar
JERSEY MUD
sorry the tires are dayton timmberline a/t's if that helps
Old Apr 2, 2011 | 11:44 PM
JERSEY MUD's Avatar
JERSEY MUD
Old Apr 2, 2011 | 11:45 PM
ije83's Avatar
ije83
i wouldnt assume the drive shaft right off the bat...especially if it wasnt doing this before the lift blocks. have the tires been rotated recently? balanced? what makes you think the driveshaft is the issue? all nuts and bolts properly torqued down? u joints in good condition?
Old Apr 2, 2011 | 11:48 PM
JERSEY MUD's Avatar
JERSEY MUD
when i coast it stops. tires need to be roated. 80 pounds of torque, u joints are 3 years old. my old mans gonna skin my *** alive
Old Apr 2, 2011 | 11:51 PM
JERSEY MUD's Avatar
JERSEY MUD
the shocks are standerd size 2'' lift
Old Apr 3, 2011 | 12:03 AM
JERSEY MUD's Avatar
JERSEY MUD
the kit said to remove oem shims
Old Apr 3, 2011 | 01:13 AM
greystreak92's Avatar
greystreak92
You say it stops when you let the truck coast? I'll bet dollars to doughnuts that the double-cardon u-joint at the front of the rear drive shaft is the culprit. However, if they were all new three years ago, I'd be concerned that adding the blocks put your driveshaft geometry off. Every lift I've ever done has kept the factory shims at the very least. Unless the blocks you added are tapered to compensate for the change in geometry, this may be the root of the problem.
Old Apr 3, 2011 | 09:06 AM
njneer1's Avatar
njneer1
Greystreak is right.......the blocks would need to be tapered to remove the stock shims......if they are tapered , you didn't put you blocks on backwards did you ? pinion angle should be increased...... Post up some pics for us to take a look
purplepowercat1
Jun 3, 2016 01:25 PM
jtapal
20
Jan 7, 2016 10:24 PM
OneSickTruck
Nov 16, 2014 10:36 AM
brainchild
Oct 26, 2005 08:07 PM
