Yes, Im new
Old Apr 2, 2011 | 10:36 PM
wiredpenguin's Avatar
wiredpenguin
Yes, Im new
Im wondering if someone can clear up my issue? I have a new project starting with a ford 302 connecting it to a np435 and then to a dana 300. the motor came out of a 80s f150 with no bell housing. the tranny came from a late 70s f150 with a bellhousing. The bell housing doesnt fit the motor. I dont know what motor the tranny was hooked to, could it have been a big block?, the bell just seems two big, but does have the same bolt pattern just bigger. can someone help a first timer?????
Old Apr 3, 2011 | 03:36 AM
jejdavis's Avatar
jejdavis
In the 70's there was a lot of different motors used but my guess is you don't have the right bell housing. Most 70's either had FE usually a 360 or M series such as 351M, 400, 460.
Old Apr 3, 2011 | 02:21 PM
85e150's Avatar
85e150
Probably one of the top ten reasons people throw up their hands and just go build a Chevy is Ford's idiotic practice of making a different bell pattern for every engine series.
Here's a list, no guarantee it's 100% correct.
List of Ford bellhousing patterns - Wikipedia, the free encyclopedia
But, since you are dealing with a 302, you need the bell off a truck 302 so you will have the correct block to bell pattern, and correct depth.
The 351w uses the same pattern, as does the 240/300 six. NOT SURE you can use the six bell. The 351w bell should work. (starter location would be the deal killer)
But your late '70s bell would be of value to some other person in need of one for whatever it came off of.
Old Apr 3, 2011 | 05:16 PM
wiredpenguin
thank you!! so a differnt bell houseing is needed and shouldnt be hard to find. I talk to the guy that sold me the tranny, he thought a 351 was hooked to it??? the numbers on the bell are half worn off so who knows. thanks again
thank you!
Old Apr 3, 2011 | 05:21 PM
wiredpenguin
thanks! sounds like te right one shouldnt be hard to find
Old Apr 3, 2011 | 09:43 PM
mparago15's Avatar
mparago15
you can try advanceadapters.com i found it to be very helpful for my truck
Old Apr 3, 2011 | 10:39 PM
85e150's Avatar
85e150
AA can be helpful, but he doesn't need an adaptor, he can get a stock Ford bell.
steve33444
19
Aug 25, 2015 08:49 AM
Bulldog f150
29
Feb 7, 2014 09:44 AM
trumsey07
Apr 17, 2011 11:35 AM
toolz_not_toyz
Jul 26, 2004 09:29 AM
magic_man77
Dec 2, 2002 06:27 AM
